No ethernet in petalinux 2016.4
Hi, I've tried to use ethernet but I can't get connected. There's no folder device-tree folder under project-spec/meta-user/recipes-bsp so I can't modify the system-user.dtsi
Re: No ethernet in petalinux 2016.4
In 2016.4, device tree files resides in below path
/project-spec/meta-user/recipes-dt/device-tree
Best Regards
Shabbir
Best Regards
Shabbir
