Visitor phjonesisu
No filesystem could mount root, when booting Xilinx open source Linux on ML507
I am a new professor at Iowa State University (Ames, IA).  And am looking to integrate the Xilinx open source Linux, and the ML507 into my classes, and research.
I’ve been going through the GREAT directions that have been provided at: http://xilinx.wikidot.com/configuring-building-and-loading-linux-after-9-1-08  and believe I am very close to getting the Xilinx open source Linux to fully boot.  However it crashes with the following message:
No filesystem could mount root, tried:  ext2 cramfs vfat msdos romfs
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(1,0)
Rebooting in 180 seconds..
It looks like the initrd image, which has the ramdisk in the kernel image, is not being loaded.  Which is named:
simpleImage.initrd.virtex440-ml507
 However I do not see how one goes about loading the initrd image.
        I ran the following commands:
make ARCH=powerpc 44x/virtex5_defconfig
make ARCH=powerpc zImage
XMD% connect ppc hw -debugdevice deviceNr 5 cpunr 1
XMD% dow arch/powerpc/boot/simpleImage.virtex440-ml507.elf
XMD% run
I did make a small change to my virtex440-ml507.dts file to give the OS a static IP
Changed from: bootargs = "console=ttyS0 ip=on root=/dev/ram";
                   to:       bootargs = "console=ttyS0 ip=192.168.1.10 root=/dev/ram";
I have attached my .dts file.
Here is the output from minicom when the OS tries to boot:
Linux/PowerPC load: console=ttyS0 ip=192.168.1.10 root=/dev/ram
Finalizing device tree... flat tree at 0x5a3300
Using Xilinx Virtex440 machine description
Linux version 2.6.28-rc6 (phjones@xilinx.ece.iastate.edu) (gcc version 4.0.0 (D8
Zone PFN ranges:
  DMA      0x00000000 -> 0x00010000
  Normal   0x00010000 -> 0x00010000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0: 0x00000000 -> 0x00010000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
Kernel command line: console=ttyS0 ip=192.168.1.10 root=/dev/ram
Xilinx intc at 0x81800000 mapped to 0xfdfff000
PID hash table entries: 1024 (order: 10, 4096 bytes)
clocksource: timebase mult[a00000] shift[22] registered
Console: colour dummy device 80x25
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 256128k/262144k available (3172k kernel code, 5776k reserved, 136k data)
Calibrating delay loop... 798.72 BogoMIPS (lpj=1597440)
Mount-cache hash table entries: 512
net_namespace: 636 bytes
PCI: Probing PCI hardware
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
msgmni has been set to 500
io scheduler noop registered
io scheduler anticipatory registered
Serial: 8250/16550 driver4 ports, IRQ sharing disabled
83e00000.serial: ttyS0 at MMIO 0x83e01003 (irq = 16) is a 16550A
console [ttyS0] enabled
brd: module loaded
loop: module loaded
Device Tree Probing 'ethernet'
xilinx_lltemac 81c00000.ethernet: MAC address is now  2: 0: 0: 0: 0: 0
xilinx_lltemac 81c00000.ethernet: XLlTemac: using DMA mode.
XLlTemac: DCR address: 0x80
XLlTemac: buffer descriptor size: 32768 (0x8000)
XLlTemac: Allocating DMA descriptors with kmalloc<6>XLlTemac: (buffer_descripto0
XTemac: PHY detected at address 7.
xilinx_lltemac 81c00000.ethernet: eth0: Xilinx TEMAC at 0x81C00000 mapped to 0x7
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
TCP cubic registered
eth0: XLlTemac: Options: 0x3fa
eth0: XLlTemac: allocating interrupt 19 for dma mode tx.
eth0: XLlTemac: allocating interrupt 18 for dma mode rx.
eth0: XLlTemac: speed set to 1000Mb/s
eth0: XLlTemac: Send Threshold = 24, Receive Threshold = 4
eth0: XLlTemac: Send Wait bound = 254, Receive Wait bound = 254
IP-Config: Guessing netmask 255.255.255.0
IP-Config: Complete:
     device=eth0, addr=192.168.1.10, mask=255.255.255.0, gw=255.255.255.255,
     host=192.168.1.10, domain=, nis-domain=(none),
     bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath=
List of all partitions:
Thank you for any suggestions you have.
Phillip.
Visitor phjonesisu
Re: No filesystem could mount root, when booting Xilinx open source Linux on ML507
Issue fixed.
The wiki page has been updated to give more detials on using a ramdisk.
 The fundumental issue I was having was that I was not placing "ramdisk.image.gz" in the arch/powerpc/boot directory.  And I did not realize you have to download this file from:
http://xilinx.wikidot.com  (click on "file" at the bottom of the page to make the file downlaod options appear)
 I would also think their should be a way to make your own "ramdisk.image.gz"??
 Note: if you are using a ramdisk (i.e. kernel commnad line has "root=/dev/ram"), then
Instead of running:  XMD% dow arch/powerpc/boot/simpleImage.virtex440-ml507.elf, as shown on the wiki page
run:  XMD% dow arch/powerpc/boot/simpleImage.initrd.virtex440-ml507.elf
Thanks for updating the wiki page!
Phillip.
Hi Phillip,
It looks like you’re not loading the initrd image which has the ramdisk in the kernel image.
You need to load this image to use the ram disk.
I updated the wiki with a ramdisk section which should better answer this question.
-- John
Visitor phjonesisu
Issue fixed.
Phillip.
Visitor tomams
to mount nfs
bootargs:  root=/dev/nfs rw ip=on
tom
Anonymous
Not applicable
Take a look at this post for modifying the ramdisk image:
http://forums.xilinx.com/xlnx/board/message?board.id=ELINUX&message.id=1089#M1089
Terry
