No option in PetaLinux 2016.4 to disable getty
For PetaLinux 2016.4, I need to disable getty from automatically accessing the serial port, ttyPS0, so that it can be used for other purposes. I didn’t have this problem with any earlier PetaLinux version (2015.4 through 2016.3), and I don’t see any Menuconfig setting to do this.
Thanks in advance for any help.
Re: No option in PetaLinux 2016.4 to disable getty
I think even if you use kill -19, the process will respawn due to the entry "PS0:12345:respawn:/bin/start_getty 115200 ttyPS0" line inserted in the "/etc/inittab" file. This is a change in 2016.4 as the entry is coming from Yocto flow and can be seen in the Petalinux install at: $PETALINUX_INSTALL/components/yocto/source/arm/layers/poky/meta/recipes-core/sysvinit/ and refer to file: sysvinit-inittab_2.88dsf.bb where the entries are present
for i in $tmp
    do
        j=`echo ${i} | sed s/\;/\ /g`
        l=`echo ${i} | sed -e 's/tty//' -e 's/^.*;//' -e 's/;.*//'`
        label=`echo $l | sed 's/.*\(....\)/\1/'`
        echo "$label:12345:respawn:${base_bindir}/start_getty ${j}" >> ${D}${sysconfdir}/inittab
    done
We can disable these entries in the Petalinux Installation which would be further propagated in the build.
Debraj
Can you try this:
systemctl stop serial-getty@ttyPS0.service
systemctl mask serial-getty@ttyPS0.service
Best Regards
Shabbir
"systemctl" is not present in PetaLinux.
I have discovered that "kill -19" will prevent the "start_getty" process from respawning, but a real solution would prevent the "PS0:12345:respawn:/bin/start_getty 115200 ttyPS0" line from being inserted in the "/etc/inittab" file.
for i in $tmp
    do
    done
Debraj
