fiedel
No pl.dtsi after importing .hdf file in Petalinux 2018.3.
In order to ease modification of PL part, I made the axi interface from Zynq subsystem (with necessary parts like axi_dma, ...) as external, and instantiated the block design at the top level together with PL. I was running non-project mode, so I exported hardware using commands:
write_hwdef -file $hardwaredef -force
write_bitstream -force $bitstream
write_sysdef -hwdef $hardwaredef -bitfile $bitstream -file $sysdef -force
After I imported the .hdf file in petalinux, I didn't find pl.dtsi in ./components/plnx_workspace/device-tree/device-tree/.
Which step did I go wrong? How can I get .hdf file which can enable pl.dtsi generation?
fiedel
It seems pl.dtsi won't be created until the project is built.
florentw
HI @fiedel
Yes, importing the hdf will not create the pl.dtsi file.
You need to run the device tree generator for this. So you can build omly the device tree or run a full build
Florent
