sourajitjash
Not able to boot Linaro on Zedboard from Linux-xilinx repository. Although was able to boot from Linux-Digilent repository
 I am booting linaro on Zedboard from Linux-digilent repository building kernel and all: zImage, BOOT.BIN, devitree.dtb.
But I am not able to boot linaro on Zedbaord while starting from Linux-Xilinx repository(https://github.com/Xilinx/linux-xlnx). I need it very urgent. Basically for linux-xilinx case, necessary files to boot linaro are : uImage, BOOT.BIN, devicetree.dtb.
I built devicetree.dtb and uImage from xilinx-linux and used BOOT.BIN of my digilent case. Is it because of the u-boot, contained in BOOT.BIN. U-Boot has information on uImage or zImage???
Can anyone provide working files: uImage, BOOT.BIN and devicetree.dtb for ZEDBoard to boot Linaro. So that I can make changes and compare.
vgokhale
The Xilinx wiki on setting up a Linux system is quite clear. If you follow it, you should have no problems. As you already see, it mentions uImage. So if you follow this, you should have all you need.
