Observer derekparks
Not able to send/recv packets in Linux
Using custom board with
Linux 4.9.0
Zynq-7100
macb Cadence
TI DP83867 phy
The mac&phy drivers seem to initialize and configured properly as seen in this snip of the Linux startup:
libphy: Fixed MDIO Bus: probed
CAN device driver interface
libphy: MACB_mii_bus: probed
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 29 (00:0a:35:00:1e:29)
TI DP83867 e000b000.etherne:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=e000b000.etherne:0c, irq=-1)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Link lights are on and blinking, ethtool shows negotiation is completed with the other side (tried switch and direct PC connection).
But no pings leave the board nor do any pings enter.  Any help is appreciated.
Re: Not able to send/recv packets in Linux
Can you post your device tree entry for the MAC? Do you see an ARP request coming out when you ping?
Terry
Visitor ptynan3
Here is the excerpt from our dtsi file:
&gem0 {
                phy-handle = <&ethernet_phy>;
    status = "okay";
    phy-mode = "rgmii-id";
    pinctrl-names = "default";
    xlnx,eth-mode = <0x1>;
                /delete-node/ ethernet-phy@7;
    mdio {
        status = "okay";
        #address-cells = <1>;
        #size-cells = <0>;
        ethernet_phy: ethernet-phy@c {
            compatible = "ti,dp83867", "ethernet-phy-ieee802.3-c22";
            device_type = "ethernet-phy";
                                                reg = <0xc>;
            ti,rx-internal-delay = <0xc>;
            ti,tx-internal-delay = <0xa>;
            ti,fifo-depth = <0x01>;
            ti,min-output-impedance;
            status = "okay";
We are able to negotiate 100M with these settings, but we get frame errors for 1G at all 16 possible rx delays.
Observer derekparks
@terryo, we do see ARPs sending out the TX.  Additionally, i manually enter an arp entry and see that pings are leaving.  And finally, the pings are received and replied too by the receiving end (a windows PC).   We've tried the link you posted and even tried all 16 different rx delay settings...0x0-0xf.  I've attached dmesg output.
Did you look into the dp83867-rxctrl-strap-quirk setting to see if that might apply to you?
Observer derekparks
Tried both quirk settings.  Furthermore, found out that our 'mode=3' and don't need the quirk.
Hi @derekparks,
If you are able to ping at 100 and face issues are 1000, then it could be related to PHY tuning. Please check that the GEM reference clock is being supplied at 125MHz when using 1G – this happens by default with CCF but if you have any customizations, it might be worth checking. Once, that is verified, as you to tune the TX delay value and then once all TX packets are visible with no errors in wireshark on the other end, switch to tuning RX delay. Just to verify you can set both to maximum first. Also, “xlnx,eth-mode = <0x1>;” is not required. And the entire ethernet phy node can be directly placed in gem0 node without need for mdio node. Also, I’m guessing you checked that use of “ti,min-output-impedance” is required for your setup.
Also, please check the MAC statistics registers to check TX/RX packets and errors.
"Don't forget to reply, kudo and accept as solution."
Observer derekparks
We were able to see clock changes between 125 and 25MHz when switching between a 1000 and 100Mbps switch, so the clock rate seems to be ruled out.  I've also built without the mdio, min-output-impedance, and eth-mode and have same results.
Hi @derekparks,
How about tunning on the TX and RX? Have you done as what I suggested?
Observer derekparks
We have tried tuning the rx and tx. Seems tuning the tx doesn't matter what the settings are. There has been some positive results in selecting the higher end of the delay values, but nothing that has proved to be a fix.
I believe there is an issue with how we are using our Petalinux environment to develop. We have used a zc706 testing board to develop with an fmc5 daughter card to test ADC chips. I created the the Petalinux env using download an Xilinx board support package (bsp) binary. When our custom boards arrived, i continued to use the same environment and should move into a new environment. The one thing i was trying to avoid is having to configuration manage two software branches with roughly %90 similar code bases. Any thoughts on CM are appreciated.
Hi @derekparks,
I'm not sure which Petalinux environment are you talking about.
You mean petalinux config files?
We support only GIT as subversion tools. We have some limitations in 2017.1/2 using git for petalinux project and it is fixed in 2017.3 onwards.
Sandeep
