OF: graph: no port node found in /amba/xilinx_drm
Hi:
I use rdf0429-zcu102-es2-base-trd-2017-2-rev2  project.  I connect a monitor to zuc102 evalution board.Monitor is dell 1920*1080.  But i find a error message :  " OF: graph: no port node found in /amba/xilinx_drm " . Now, i want to know whta cause this error? Is monitor incompalitable ? Can anyone give me a suggestion?
Thanks!
root@zcu102_base_trd:~# cat /var/log/messages
Dec 7 08:45:08 zcu102_base_trd syslog.info syslogd started: BusyBox v1.24.1
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: klogd started: BusyBox v1.24.1 (2017-11-29 17:32:44 CST)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] Linux version 4.9.0 (ceshiyiqi@ceshiyiqi-HP-Pro-3340-MT) (gcc version 67
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] Boot CPU: AArch64 Processor [410fd034]
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] bootconsole [cdns0] enabled
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] cma: Reserved 1024 MiB at 0x000000002e000000
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 0.000000] On node 0 totalpages: 1048576
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 0.000000] DMA zone: 7168 pages used for memmap
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 0.000000] DMA zone: 0 pages reserved
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 0.000000] DMA zone: 524288 pages, LIFO batch:31
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 0.000000] Normal zone: 7168 pages used for memmap
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 0.000000] Normal zone: 524288 pages, LIFO batch:31
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] psci: probing for conduit method from DT.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] psci: PSCIv1.0 detected in firmware.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff67000 s46232 r8192 d31592 u86016
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 0.000000] pcpu-alloc: s46232 r8192 d31592 u86016 alloc=21*4096
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] Detected VIPT I-cache on CPU0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] CPU features: enabling workaround for ARM erratum 845719
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 10340
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] Kernel command line: earlycon clk_ignore_unused earlyprintk uio_pdrv_geM
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] software IO TLB [mem 0x2a000000-0x2e000000] (64MB) mapped at [ffffffc02a0]
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] Memory: 2741680K/4194304K available (8830K kernel code, 578K rwdata, 2780)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] Virtual kernel memory layout:
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008920000 ( 8832 KB)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] .rodata : 0xffffff8008920000 - 0xffffff8008be0000 ( 2816 KB)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] .init : 0xffffff8008be0000 - 0xffffff8008c50000 ( 448 KB)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] .data : 0xffffff8008c50000 - 0xffffff8008ce0808 ( 579 KB)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] .bss : 0xffffff8008ce0808 - 0xffffff8008d6f5b4 ( 572 KB)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maxi)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] 0xffffffbf00000000 - 0xffffffbf1dc00000 ( 476 MB actu)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc880000000 ( 34816 MB)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] Hierarchical RCU implementation.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] Build-time adjustment of leaf fanout to 64.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] NR_IRQS:64 nr_irqs:64 0
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] GIC: Using split EOI/Deactivate mode
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 100.00MHz (phys).
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x17102s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.000003] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 439804651110s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.008351] Console: colour dummy device 80x25
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.012610] console [tty0] enabled
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.015976] bootconsole [cdns0] disabled
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.019883] Calibrating delay loop (skipped), value calculated using timer frequency.)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.019896] pid_max: default: 32768 minimum: 301
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.019996] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.020006] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.020525] ASID allocator initialised with 65536 entries
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.021015] zynqmp_plat_init Power management API v0.3
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.021392] Detected VIPT I-cache on CPU1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.021419] CPU1: Booted secondary processor [410fd034]
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.021667] Detected VIPT I-cache on CPU2
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.021684] CPU2: Booted secondary processor [410fd034]
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.021928] Detected VIPT I-cache on CPU3
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.021945] CPU3: Booted secondary processor [410fd034]
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.021979] Brought up 4 CPUs
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.022010] SMP: Total of 4 processors activated.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.022019] CPU features: detected feature: 32-bit EL0 Support
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.022028] CPU: All CPU(s) started at EL2
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.022043] alternatives: patching kernel code
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.022705] devtmpfs: initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.027941] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.049200] xor: measuring software checksum speed
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.088033] 8regs : 2303.000 MB/sec
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.128062] 8regs_prefetch: 2053.000 MB/sec
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.168092] 32regs : 2830.000 MB/sec
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.208123] 32regs_prefetch: 2379.000 MB/sec
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.208135] xor: using function: 32regs (2830.000 MB/sec)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.208213] pinctrl core: initialized pinctrl subsystem
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.208682] NET: Registered protocol family 16
Dec 7 08:45:08 zcu102_base_trd user.err kernel: [ 0.209549] Failed to initialise IOMMU /amba/smmu@fd800000
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.209735] vdso: 2 pages (1 code @ ffffff8008927000, 1 data @ ffffff8008c54000)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.209759] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.210222] DMA: preallocated 256 KiB pool for atomic allocations
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.220324] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.220731] ARM CCI_400_r1 PMU driver probed
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.223501] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 0.223898] Write failed gate address:1000f02
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.223964] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 41, base_baud = 6249375s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.727713] console [ttyPS0] enabled
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.751933] HugeTLB registered 2 MB page size, pre-allocated 0 pages
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.826420] raid6: int64x1 gen() 407 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.898383] raid6: int64x1 xor() 443 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 0.970437] raid6: int64x2 gen() 671 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.042470] raid6: int64x2 xor() 600 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.114509] raid6: int64x4 gen() 983 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.186549] raid6: int64x4 xor() 739 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.258626] raid6: int64x8 gen() 1146 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.330659] raid6: int64x8 xor() 747 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.402698] raid6: neonx1 gen() 721 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.474740] raid6: neonx1 xor() 758 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.546815] raid6: neonx2 gen() 1166 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.618845] raid6: neonx2 xor() 1035 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.690906] raid6: neonx4 gen() 1506 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.762956] raid6: neonx4 xor() 1181 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.834996] raid6: neonx8 gen() 1585 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.907045] raid6: neonx8 xor() 1221 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.911230] raid6: using algorithm neonx8 gen() 1585 MB/s
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.916610] raid6: .... xor() 1221 MB/s, rmw enabled
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.921558] raid6: using intx1 recovery algorithm
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 1.930460] SCSI subsystem initialized
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 1.934178] libata version 3.00 loaded.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.934318] usbcore: registered new interface driver usbfs
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.939760] usbcore: registered new interface driver hub
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.945059] usbcore: registered new device driver usb
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.950124] media: Linux media interface: v0.10
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.954603] Linux video capture interface: v2.00
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.959203] pps_core: LinuxPPS API ver. 1 registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.964127] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <gio>
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.973260] PTP clock support registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.977166] EDAC MC: Ver: 3.0.0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.980491] FPGA manager framework
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.983927] Advanced Linux Sound Architecture Driver Initialized.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.990204] Bluetooth: Core ver 2.22
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.993712] NET: Registered protocol family 31
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 1.998128] Bluetooth: HCI device and connection manager initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.004468] Bluetooth: HCI socket layer initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.009326] Bluetooth: L2CAP socket layer initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.014368] Bluetooth: SCO socket layer initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.019703] clocksource: Switched to clocksource arch_sys_counter
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 2.025783] VFS: Disk quotas dquot_6.6.0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.029703] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.039908] NET: Registered protocol family 2
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.044502] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.051860] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.058818] TCP: Hash tables configured (established 32768 bind 32768)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.065304] UDP hash table entries: 2048 (order: 4, 65536 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.071329] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.077841] NET: Registered protocol family 1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.082313] RPC: Registered named UNIX socket transport module.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.088169] RPC: Registered udp transport module.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.092843] RPC: Registered tcp transport module.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.097529] RPC: Registered tcp NFSv4.1 backchannel transport module.
Dec 7 08:45:08 zcu102_base_trd user.debug kernel: [ 2.103956] PCI: CLS 0 bytes, default 128
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 2.104090] Trying to unpack rootfs image as initramfs...
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.745768] Freeing initrd memory: 260652K (ffffffc06e03a000 - ffffffc07dec5000)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.753386] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.761625] futex hash table entries: 1024 (order: 5, 131072 bytes)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.767863] audit: initializing netlink subsys (disabled)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 13.773231] audit: type=2000 audit(13.508:1): initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.778997] workingset: timestamp_bits=62 max_order=20 bucket_order=0
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 13.785978] NFS: Registering the id_resolver key type
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 13.790969] Key type id_resolver registered
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 13.795115] Key type id_legacy registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.799112] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.805805] jffs2: version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.820189] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.827527] io scheduler noop registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.831416] io scheduler deadline registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.835676] io scheduler cfq registered (default)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.841386] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.847949] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.854945] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.861938] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.868927] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.875925] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.882917] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.889906] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.896902] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.903924] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.910914] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.917909] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.924904] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.931903] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.938899] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.945894] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.952897] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.980787] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.987971] [drm] Initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.991304] [drm] load() is defered & will be called again
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 13.997122] xilinx-drm-dp-sub fd4aa000.dp_sub: Xilinx DisplayPort Subsystem is probed
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 14.005039] Unable to detect cache hierarchy from DT for CPU 0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.014848] brd: module loaded
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.020342] loop: module loaded
Dec 7 08:45:08 zcu102_base_trd user.err kernel: [ 14.024044] ahci-ceva fd0c0000.ahci: couldn't get PHY in node ahci: -517
Dec 7 08:45:08 zcu102_base_trd user.err kernel: [ 14.030774] mtdoops: mtd device (mtddev=name/number) must be supplied
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 14.037840] m25p80 spi0.0: found n25q512a, expected m25p80
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.043375] m25p80 spi0.0: n25q512a (131072 Kbytes)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 14.048188] 4 ofpart partitions found on MTD device spi0.0
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 14.053642] Creating 4 MTD partitions on "spi0.0":
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 14.058417] 0x000000000000-0x000001e00000 : "boot"
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 14.063626] 0x000001e00000-0x000001e40000 : "bootenv"
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 14.068995] 0x000001e40000-0x000004240000 : "kernel"
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 14.074285] 0x000004240000-0x000008000000 : "spare"
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.080217] libphy: Fixed MDIO Bus: probed
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.085283] tun: Universal TUN/TAP device driver, 1.6
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.090259] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.096504] CAN device driver interface
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.102181] macb ff0e0000.ethernet: Not enabling partial store and forward
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.109348] libphy: MACB_mii_bus: probed
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.116487] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.126246] TI DP83867 ff0e0000.etherne:0c: attached PHY driver [TI DP83867] (mii_bus)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.137874] usbcore: registered new interface driver asix
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.143241] usbcore: registered new interface driver ax88179_178a
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.149295] usbcore: registered new interface driver cdc_ether
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.155109] usbcore: registered new interface driver net1080
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.160752] usbcore: registered new interface driver cdc_subset
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.166654] usbcore: registered new interface driver zaurus
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.172222] usbcore: registered new interface driver cdc_ncm
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.179142] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.185597] ehci-pci: EHCI PCI platform driver
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.190244] usbcore: registered new interface driver uas
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.195516] usbcore: registered new interface driver usb-storage
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.201712] mousedev: PS/2 mouse device common for all mice
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.207544] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.214734] i2c /dev entries driver
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.218633] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 33
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 14.224640] 0-0020 supply vcc not found, using dummy regulator
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.231095] GPIO line 322 (sel0) hogged as output/high
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.236351] GPIO line 323 (sel1) hogged as output/high
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.241603] GPIO line 324 (sel2) hogged as output/high
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.246860] GPIO line 325 (sel3) hogged as output/high
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 14.252015] pca953x 0-0020: interrupt support not compiled in
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 14.257736] 0-0021 supply vcc not found, using dummy regulator
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 14.264057] pca953x 0-0021: interrupt support not compiled in
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.270167] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 34
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.276952] i2c i2c-0: Added multiplexed i2c bus 2
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.282117] i2c i2c-0: Added multiplexed i2c bus 3
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.287528] i2c i2c-0: Added multiplexed i2c bus 4
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.292343] i2c i2c-0: Added multiplexed i2c bus 5
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.297058] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.304967] at24 6-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.311610] i2c i2c-1: Added multiplexed i2c bus 6
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.316513] i2c i2c-1: Added multiplexed i2c bus 7
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.323184] si570 8-005d: registered, current frequency 300000000 Hz
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.329473] i2c i2c-1: Added multiplexed i2c bus 8
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.348076] si570 9-005d: registered, current frequency 148500000 Hz
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.354365] i2c i2c-1: Added multiplexed i2c bus 9
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.359274] i2c i2c-1: Added multiplexed i2c bus 10
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.364176] i2c i2c-1: Added multiplexed i2c bus 11
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.369076] i2c i2c-1: Added multiplexed i2c bus 12
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.373969] i2c i2c-1: Added multiplexed i2c bus 13
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.378771] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.386523] i2c i2c-1: Added multiplexed i2c bus 14
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.391423] i2c i2c-1: Added multiplexed i2c bus 15
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.396326] i2c i2c-1: Added multiplexed i2c bus 16
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.401453] i2c i2c-1: Added multiplexed i2c bus 17
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.406354] i2c i2c-1: Added multiplexed i2c bus 18
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.411258] i2c i2c-1: Added multiplexed i2c bus 19
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.416161] i2c i2c-1: Added multiplexed i2c bus 20
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.421070] i2c i2c-1: Added multiplexed i2c bus 21
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.425869] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.433708] vivid-000: using single planar format API
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.440063] vivid-000: V4L2 capture device registered as video0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.445972] vivid-000: V4L2 output device registered as video1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.451783] vivid-000: V4L2 capture device registered as vbi0, supports raw and sliceI
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.460035] vivid-000: V4L2 output device registered as vbi1, supports raw and slicedI
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.468202] vivid-000: V4L2 capture device registered as swradio0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.474269] vivid-000: V4L2 receiver device registered as radio0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.480259] vivid-000: V4L2 transmitter device registered as radio1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.487543] usbcore: registered new interface driver uvcvideo
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.493214] USB Video Class driver (1.1.1)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.497851] ina2xx 2-0040: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.504462] ina2xx 2-0041: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.511075] ina2xx 2-0042: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.517686] ina2xx 2-0043: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.524294] ina2xx 2-0044: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.530908] ina2xx 2-0045: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.537521] ina2xx 2-0046: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.544133] ina2xx 2-0047: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.550741] ina2xx 2-004a: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.557359] ina2xx 2-004b: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.564038] ina2xx 3-0040: power monitor ina226 (Rshunt = 2000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.570657] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.577272] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.583882] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.590496] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.597110] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.603734] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.610339] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 14.630549] random: fast init done
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.649939] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff80092bf000 wits
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.658987] Bluetooth: HCI UART driver ver 2.3
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.663355] Bluetooth: HCI UART protocol H4 registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.668471] Bluetooth: HCI UART protocol BCSP registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.673765] Bluetooth: HCI UART protocol LL registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.678885] Bluetooth: HCI UART protocol ATH3K registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.684267] Bluetooth: HCI UART protocol Three-wire (H5) registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.690555] Bluetooth: HCI UART protocol Intel registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.695936] Bluetooth: HCI UART protocol Broadcom registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.701542] Bluetooth: HCI UART protocol QCA registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.706786] usbcore: registered new interface driver bcm203x
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.712421] usbcore: registered new interface driver bpa10x
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.717978] usbcore: registered new interface driver bfusb
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.723445] usbcore: registered new interface driver btusb
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.728884] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.734572] usbcore: registered new interface driver ath3k
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.740107] EDAC MC: ECC not enabled
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.743731] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV )
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.752769] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynq)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.765072] sdhci: Secure Digital Host Controller Interface driver
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.771173] sdhci: Copyright(c) Pierre Ossman
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.775510] sdhci-pltfm: SDHCI platform and OF driver helper
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.827715] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bt
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.835930] ledtrig-cpu: registered to indicate activity on CPUs
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.843987] usbcore: registered new interface driver usbhid
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.849484] usbhid: USB HID core driver
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.854973] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.863860] xilinx-dp-snd-pcm amba:dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.871474] xilinx-dp-snd-pcm amba:dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.879256] PLL: shutdown
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 14.882701] Write failed to divider address:fd1a007c
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.887743] PLL: enable
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.890279] xilinx-dp-snd-codec amba:dp_snd_codec0: Xilinx DisplayPort Sound Codec prd
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.898682] xilinx-dp-snd-card amba:dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dk
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.908786] xilinx-dp-snd-card amba:dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dk
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.919074] xilinx-dp-snd-card amba:dp_snd_card: Xilinx DisplayPort Sound Card probed
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.921405] mmc0: new high speed SDHC card at address aaaa
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.921622] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.923196] mmcblk0:
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.939029] pktgen: Packet Generator for packet performance testing. Version: 2.75
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.946683] Netfilter messages via NETLINK v0.30.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.951415] ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.956688] Initializing XFRM netlink socket
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.960942] NET: Registered protocol family 10
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.965722] ip6_tables: (C) 2000-2006 Netfilter Core Team
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.971076] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.977253] NET: Registered protocol family 17
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.981629] NET: Registered protocol family 15
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.986055] bridge: filtering via arp/ip/ip6tables is no longer available by default..
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 14.998989] Ebtables v2.0 registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.002569] can: controller area network core (rev 20120528 abi 9)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.008730] NET: Registered protocol family 29
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.013134] can: raw protocol (rev 20120528)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.017380] can: broadcast manager protocol (rev 20161123 t)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.023025] can: netlink gateway (rev 20130117) max_hops=1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.028543] Bluetooth: RFCOMM TTY layer initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.033357] Bluetooth: RFCOMM socket layer initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.038479] Bluetooth: RFCOMM ver 1.11
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.042207] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.047499] Bluetooth: BNEP filters: protocol multicast
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.052713] Bluetooth: BNEP socket layer initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.057656] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.063561] Bluetooth: HIDP socket layer initialized
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.068673] 9pnet: Installing 9P2000 support
Dec 7 08:45:08 zcu102_base_trd user.notice kernel: [ 15.072875] Key type dns_resolver registered
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.077464] registered taskstats version 1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.081843] Btrfs loaded, crc32c=crc32c-generic
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.092058] PLL: shutdown
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.094728] [drm] load() is defered & will be called again
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.100754] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.108752] xilinx-drm-dp fd4a0000.dp: device found, version 4.010
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.114882] xilinx-drm-dp fd4a0000.dp: Display Port, version 1.0200 (tx)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.121753] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.139617] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl e
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.148509] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio sl
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.158688] scsi host0: ahci-ceva
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.162098] scsi host1: ahci-ceva
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.165426] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 39
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.173274] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 39
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.182689] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.211841] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.217261] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.225107] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.233749] xhci-hcd xhci-hcd.0.auto: irq 220, io mem 0xfe200000
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.239801] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.246513] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.253719] usb usb1: Product: xHCI Host Controller
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.258572] usb usb1: Manufacturer: Linux 4.9.0 xhci-hcd
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.263869] usb usb1: SerialNumber: xhci-hcd.0.auto
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.268967] hub 1-0:1.0: USB hub found
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.272662] hub 1-0:1.0: 1 port detected
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.276656] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.282069] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.289796] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.296510] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.303716] usb usb2: Product: xHCI Host Controller
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.308569] usb usb2: Manufacturer: Linux 4.9.0 xhci-hcd
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.313863] usb usb2: SerialNumber: xhci-hcd.0.auto
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.318932] hub 2-0:1.0: USB hub found
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.322620] hub 2-0:1.0: 1 port detected
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.327005] PLL: enable
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.329564] PLL: shutdown
Dec 7 08:45:08 zcu102_base_trd user.err kernel: [ 15.332298] OF: graph: no port node found in /amba/xilinx_drm
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.337970] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.344564] [drm] No driver support for vblank timestamp query.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.375534] xilinx-drm amba:xilinx_drm: fb0: frame buffer device
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.399713] [drm] Initialized xilinx_drm 1.0.0 20130509 on minor 0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.406123] input: gpio-keys as /devices/platform/gpio-keys/input/input0
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.412878] rtc_zynqmp ffa60000.rtc: setting system clock to 2017-12-07 08:44:53 UTC )
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 15.421800] clk: Not disabling unused clocks
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.425994] ALSA device list:
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.428941] #0: DisplayPort monitor
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.429858] PLL: enable
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.493667] ata1: SATA link down (SStatus 0 SControl 330)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.499012] ata2: SATA link down (SStatus 0 SControl 330)
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 15.504483] Freeing unused kernel memory: 448K (ffffffc000be0000 - ffffffc000c50000)
Dec 7 08:45:08 zcu102_base_trd daemon.info kernel: [ 15.621949] udevd[1773]: starting version 3.2
Dec 7 08:45:08 zcu102_base_trd daemon.info kernel: [ 15.645550] udevd[1774]: starting eudev-3.2
Dec 7 08:45:08 zcu102_base_trd user.warn kernel: [ 15.717055] mali: loading out-of-tree module taints kernel.
Dec 7 08:45:08 zcu102_base_trd user.info kernel: [ 19.370017] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Found user 'avahi' (UID 999) and group 'avahi' (GID 999).
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Successfully dropped root privileges.
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: avahi-daemon 0.6.32 starting up.
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Successfully called chroot().
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Successfully dropped remaining capabilities.
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Loading service file /services/sftp-ssh.service.
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Loading service file /services/ssh.service.
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Network interface enumeration completed.
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Server startup complete. Host name is zcu102basetrd.local. Local service c.
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Service "zcu102basetrd" (/services/ssh.service) successfully established.
Dec 7 08:45:08 zcu102_base_trd daemon.info avahi-daemon[2156]: Service "zcu102basetrd" (/services/sftp-ssh.service) successfully establis.
Dec 7 08:45:08 zcu102_base_trd daemon.info ofonod[2168]: oFono version 1.18
Dec 7 08:45:08 zcu102_base_trd authpriv.notice login[2189]: ROOT LOGIN on '/dev/ttyPS0'
Dec 7 08:46:04 zcu102_base_trd user.notice kernel: [ 86.355623] random: crng init done
I would manually vote up this post.
Same here, except the name  changed in my case:
OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
Hi  haiyuan_li@mentor.com , @mrzhang_
Here is the list of monitors https://www.xilinx.com/support/answers/68671.html that works for ZynqMP devices.
With below 3 steps you can debug what's going on.
1. To debug more on this one halt at u-boot and run below commands
ZynqMP> setenv bootargs ${bootargs} drm.debug=0xe
ZynqMP> boot
2. Run modetest
 # modetest -M xilinx_drm
3. Check the SERDES Register values using devmem commands
# devmem 0xFD4001D4
# devmem 0xFD400B00
# devmem 0xFD4010CC
Sandeep
This is the output by running the commands:
root@myboard:~# modetest -M xlnx
Encoders:
id crtc type possible crtcs possible clones
37 36 TMDS 0x00000001 0x00000000
Connectors:
id encoder status name size (mm) modes encoders
38 37 connected DP-1 510x290 12 37
modes:
name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
1920x1080 60 1920 2008 2052 2200 1080 1084 1089 1125 148500 flags: phsync, pvsync; type: preferred, driver
1600x900 60 1600 1624 1704 1800 900 901 904 1000 108000 flags: phsync, pvsync; type: driver
1280x1024 75 1280 1296 1440 1688 1024 1025 1028 1066 135000 flags: phsync, pvsync; type: driver
1280x1024 60 1280 1328 1440 1688 1024 1025 1028 1066 108000 flags: phsync, pvsync; type: driver
1152x864 75 1152 1216 1344 1600 864 865 868 900 108000 flags: phsync, pvsync; type: driver
1024x768 75 1024 1040 1136 1312 768 769 772 800 78750 flags: phsync, pvsync; type: driver
1024x768 60 1024 1048 1184 1344 768 771 777 806 65000 flags: nhsync, nvsync; type: driver
800x600 75 800 816 896 1056 600 601 604 625 49500 flags: phsync, pvsync; type: driver
800x600 60 800 840 968 1056 600 601 605 628 40000 flags: phsync, pvsync; type: driver
640x480 75 640 656 720 840 480 481 484 500 31500 flags: nhsync, nvsync; type: driver
640x480 60 640 656 752 800 480 490 492 525 25175 flags: nhsync, nvsync; type: driver
720x400 70 720 738 846 900 400 412 414 449 28320 flags: nhsync, pvsync; type: driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
00ffffffffffff0010ac984042314241
281a0104a5331d783ae595a656529d27
105054a54b00714f8180a9c0d1c00101
010101010101023a801871382d40582c
4500fd1e1100001e000000ff00484d4a
3156364136414231420a000000fc0044
454c4c205032333134480a20000000fd
00384c1e5311010a20202020202000f5
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
39 sync:
flags: range
values: 0 1
value: 0
40 bpc:
flags: enum
enums: 6BPC=6 8BPC=8 10BPC=10 12BPC=12
value: 8
CRTCs:
id fb pos size
36 55 (0,0) (1920x1080)
props:
29 output_color:
flags: enum
enums: rgb=0 ycrcb444=1 ycrcb422=2 yonly=3
value: 0
30 bg_c0:
flags: range
values: 0 4095
value: 0
31 bg_c1:
flags: range
values: 0 4095
value: 0
32 bg_c2:
flags: range
values: 0 4095
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
34 0 0 0,0 0,0 0 0x00000001
formats: VYUY UYVY YUYV YVYU YU16 YV16 YU24 YV24 NV16 NV61 BG24 RG24 XB24 XR24 XB30 XR30 YU12 YV12 NV12 NV21 XV15 XV20
props:
6 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 0
33 tpg:
flags: range
values: 0 1
value: 0
35 36 55 0,0 0,0 0 0x00000001
formats: AB24 AR24 RA24 BA24 BG24 RG24 RA15 BA15 RA12 BA12 RG16 BG16
props:
6 type:
value: 1
27 alpha:
flags: range
values: 0 255
value: 255
28 g_alpha_en:
flags: range
values: 0 1
value: 1
Frame buffers:
id size pitch
root@myboard:~# devmem 0xFD4001D4
/dev/mem opened.
Memory mapped at address 0x7faf780000.
Read at address 0xFD4001D4 (0x7faf7801d0): 0x0000000000000000
root@myboard:~# devmem 0xFD400B00
/dev/mem opened.
Memory mapped at address 0x7fa762b000.
Read at address 0xFD400B00 (0x7fa762bb00): 0x0000001B00000040
root@myboard:~# devmem 0xFD4010CC
/dev/mem opened.
Memory mapped at address 0x7f96cfb000.
Read at address 0xFD4010CC (0x7f96cfb0c8): 0x0000000000000000
I don't have a monitor available in the white list. it's DELL P2217H and P2314H, pretty new monitor. one DP-DP cable. the monitors and cable have proven works on a desktop workstation.
here is the kernel log using the bootargs for drm debugging:
[ 1.794743] mmcblk0: mmc0:0007 SD16G 14.4 GiB
[ 1.809138] mmcblk0: p1 p2
[ 3.672632] console [ttyPS0] enabled
[ 3.676621] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 49, base_baud = 6250000) is a xuartps
[ 3.686787] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:8 protocol:4 pll_locked:yes
[ 3.694910] PLL: shutdown vpll_int
[ 3.699118] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[ 3.706047] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.712586] [drm] No driver support for vblank timestamp query.
[ 3.718551] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008b8cab0)
[ 3.718559] lih: DP_TX_INTR_HPD_EVENT, 0, 0
[ 3.720788] lih: zynqmp_dp_connector_detect -> dpcd read: ret=15
[ 3.720795] lih: dpcd: 11 0A 84 01 01 00 01 80 02 00 00 00 00 00 00
[ 3.720806] [drm:drm_helper_hpd_irq_event] [CONNECTOR:38:DP-1] status updated from unknown to connected
[ 3.742981] [drm:drm_setup_crtcs]
[ 3.742990] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:38:DP-1]
[ 3.745217] lih: zynqmp_dp_connector_detect -> dpcd read: ret=15
[ 3.751147] lih: dpcd: 11 0A 84 01 01 00 01 80 02 00 00 00 00 00 00
[ 3.770003] lih: zynqmp_dp_connector_get_modes - drm_get_edid return 0x76b7de00
[ 3.783608] lih: zynqmp_dp_connector_get_modes - drm_add_edid_modes return 12
[ 3.790815] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:38:DP-1] probed modes :
[ 3.790826] [drm:drm_mode_debug_printmodeline] Modeline 42:"1920x1080" 60 148500 1920 2008 2052 2200 1080 1084 1089 1125 0x48 0x5
[ 3.790834] [drm:drm_mode_debug_printmodeline] Modeline 45:"1600x900" 60 108000 1600 1624 1704 1800 900 901 904 1000 0x40 0x5
[ 3.790843] [drm:drm_mode_debug_printmodeline] Modeline 50:"1280x1024" 75 135000 1280 1296 1440 1688 1024 1025 1028 1066 0x40 0x5
[ 3.790851] [drm:drm_mode_debug_printmodeline] Modeline 44:"1280x1024" 60 108000 1280 1328 1440 1688 1024 1025 1028 1066 0x40 0x5
[ 3.790860] [drm:drm_mode_debug_printmodeline] Modeline 43:"1152x864" 75 108000 1152 1216 1344 1600 864 865 868 900 0x40 0x5
[ 3.790868] [drm:drm_mode_debug_printmodeline] Modeline 51:"1024x768" 75 78750 1024 1040 1136 1312 768 769 772 800 0x40 0x5
[ 3.790877] [drm:drm_mode_debug_printmodeline] Modeline 52:"1024x768" 60 65000 1024 1048 1184 1344 768 771 777 806 0x40 0xa
[ 3.790885] [drm:drm_mode_debug_printmodeline] Modeline 53:"800x600" 75 49500 800 816 896 1056 600 601 604 625 0x40 0x5
[ 3.790894] [drm:drm_mode_debug_printmodeline] Modeline 46:"800x600" 60 40000 800 840 968 1056 600 601 605 628 0x40 0x5
[ 3.790902] [drm:drm_mode_debug_printmodeline] Modeline 47:"640x480" 75 31500 640 656 720 840 480 481 484 500 0x40 0xa
[ 3.790910] [drm:drm_mode_debug_printmodeline] Modeline 48:"640x480" 60 25175 640 656 752 800 480 490 492 525 0x40 0xa
[ 3.790919] [drm:drm_mode_debug_printmodeline] Modeline 49:"720x400" 70 28320 720 738 846 900 400 412 414 449 0x40 0x6
[ 3.790925] [drm:drm_setup_crtcs] connector 38 enabled? yes
[ 3.790932] [drm:drm_setup_crtcs] looking for cmdline mode on connector 38
[ 3.790937] [drm:drm_setup_crtcs] looking for preferred mode on connector 38 0
[ 3.790942] [drm:drm_setup_crtcs] found mode 1920x1080
[ 3.790947] [drm:drm_setup_crtcs] picking CRTCs for 4096x4096 config
[ 3.790955] [drm:drm_setup_crtcs] desired mode 1920x1080 set on crtc 36 (0,0)
[ 3.793426] lih: zynqmp_dp_mode_configure: max_lanes=2
[ 3.793429] lih: zynqmp_dp_mode_configure: bw=270000, rate=90000, pclock=148500
[ 3.793431] lih: zynqmp_dp_mode_configure: bw=270000, rate=180000, pclock=148500
[ 3.794009] PLL: enable vpll_int
[ 3.865691] lih: zynqmp_dp_train --> entry
[ 3.873552] lih: zynqmp_dp_train reg = 3 bw_code=10 lane_cnt=2 aux_lane_cnt=130 enhanced=1
[ 3.887454] lih: zynqmp_dp_train --> return 0
[ 3.887456] lih: zynqmp_dp_train return 0
[ 3.924150] Console: switching to colour frame buffer device 240x67
[ 3.990800] zynqmp-display fd4a0000.zynqmp-display: fb0: frame buffer device
[ 3.998132] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[ 4.006239] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[ 4.015035] zynqmp_gpd_attach_dev error -13, node 47
[ 4.019966] xilinx_can ff060000.can: failed to add to PM domain pd-can0: -13
[ 4.027197] zynqmp_gpd_attach_dev error -13, node 48
[ 4.032126] xilinx_can ff070000.can: failed to add to PM domain pd-can1: -13
[ 4.040899] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:0 protocol:3 pll_locked:yes
[ 4.050982] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.056457] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 4.064345] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
[ 4.073072] xhci-hcd xhci-hcd.0.auto: irq 168, io mem 0xfe200000
[ 4.079159] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
I am using the new version of the driver (the one under drivers/gpu/drm/xlnx/).
So in my case, this command doesn't work:
$ modetest -M xilinx_drm
failed to open device 'xilinx-drm': No such file or directory
instead, should use this:
$ modetest -M xlnx
