Open BSP as a Project
In many petalinux tutorials BSPs are used as starting point. What if I need to modify the base project or see how it was implemented? There should be a way to import it back to Vivado? Or is it possible to somehow extract the hdf file to reverse engineer it?
Thanks!
There will be a hardware folder in the bsp that contains the vivado project
This is how to actuall do it:
First load the petalinux toolchain (wherever it's installed):
```bash
source /opt/Xilinx/petalinux/settings.sh
Then extract it:
```bash
petalinux-create -t project -s xilinx-zcu111-v2019.1-final.bsp
