Visitor benazir1
PETALINUX - BUilding new application - Error
I'm trying to make a simple "Hello, World" application for Petalinux and following all the steps, described in the 'Application Development and Debugging Guide'.
I created a new aplication by name Test and tried to build the application by using the following commands as described in the document
santhosha@linuxserver:Test2$ petalinux-config -c rootfs
INFO: Checking component...
INFO: Config linux/rootfs
[INFO ] config linux/rootfs
configuration written to /home/santhosha/Benazir/Test2/subsystems/linux/configs/rootfs/config
*** End of the configuration.
I entered the configuration module and selected my application 'Test' in apps, and selected yes to save the configuration, as said in the document;
The documnet says..
It will take a few seconds to apply the configuration change, please wait until you return to the shell
prompt on the command console.
BUT my control never returns to the shell command prompt even after several minutes !!
Please help or advise....
Re: PETALINUX - BUilding new application - Error
Moving to correct board.
Thanks,Vijay
Scholar sampatd
Which version of PetaLinux are you using?
Visitor benazir1
Petalinux version 2014.2;
My host OS was ubuntu 14.04, when i tried with 12.04, it worked;
Thank you;
Visitor benazir1
Obviously with additional 32 bit packages;
