lynn.zhang
PHY loopback enable
Hi, I enabled the phy loopback from bootload on zc706 board, using petalinux 2018.2:
Zynq> mii dump 7 0
0.     (5000)                 -- PHY control register --
  (8000:0000) 0.15    =     0    reset
  (4000:4000) 0.14    =     1    loopback
  (2040:0000) 0. 6,13 =   b00    speed selection = 10 Mbps
  (1000:1000) 0.12    =     1    A/N enable
  (0800:0000) 0.11    =     0    power-down
  (0400:0000) 0.10    =     0    isolate
  (0200:0000) 0. 9    =     0    restart A/N
  (0100:0000) 0. 8    =     0    duplex = half
  (0080:0000) 0. 7    =     0    collision test enable
  (003f:0000) 0. 5- 0 =     0    (reserved)
After it bootup, if I ping from board to PC, it support to fail the ping? Now I'm still able to ping it.
shabbirk
Can you once check the ping at linux level?
Best Regards
Shabbir
