PL IIC Got unexpected IRQ
I was able to get PS I2C working fine. Now i'm trying to get the PL one working. I enabled it in the driver and can see it in /dev. I can also open the device fine. But, when I try to write to it it just returns with an incorrect number of bytes written (255).
Has anyone tried the PL I2C driver? Does this device tree entry look ok?
axi_iic_0: i2c@41600000 {
compatible = "xlnx,axi-iic-1.02.a", "xlnx,xps-iic-2.00.a";
interrupt-parent = <&ps7_scugic_0>;
interrupts = <0 59 4>;
reg = <0x41600000 0x10000>;
xlnx,gpo-width = <0x1>;
xlnx,iic-freq = <0x186a0>;
xlnx,instance = "axi_iic_0";
xlnx,scl-inertial-delay = <0x0>;
xlnx,sda-inertial-delay = <0x0>;
xlnx,sda-level = <0x1>;
xlnx,ten-bit-adr = <0x0>;
Any other ideas on how to debug this? Note this is on a Zynq fwiw.
Re: PL IIC Got unexpected IRQ
if it helps, this is the device tree I ended up using
compatible = "xlnx,axi-iic-1.01.b", "xlnx,xps-iic-2.00.a";
interrupts = <0 59 0>;
#address-cells = <1>;
#size-cells = <0>;
#size-cells = <0>;
Visitor snehaputhani
Even I am facing the same issue with PL I2C driver.
My device tree looks like this:
axi_iic:i2c@41600000 {
                        compatible = "xlnx,xps-iic-2.00.a";
            reg = < 0x41600000 0x10000 >;
            #size-cells = <0>;
When I try to test the driver by typing the following on console:
echo 1 >> i2c-0
I get the following error:
xiic-i2c 41600000.i2c: xiic_process Got unexpected IRQ
Any suggestion regarding this, am I doing something wrong?
The issue of unexpected IRQ got resolved. The problem was with the interrupt number. It is supposed to be 32 and not 59 (91-32=59). The final device tree node looks like as shown below:
            interrupts = <0 32 4>;
            #size-cells = <0>;
Another issue which I am facing now is whenever I read or write to the device, I get "Error no 110" which is -ETIMEDOUT error. I am trying to resolve this issue , any hints on this would be welcome.
