11-24-2020 12:45 AM
Hi all
We have a SoC design with an 'axi datamover' in the PL interfaced to the S_AXI_HP0_FPD port of the Zynq(ZU11EG)
the PS DDR4 Configuration: 4GB / 2400P
AXI_HP0_FPD Configuration: 125MHz * 128bit
CASE1: under linux
PL send 16KB package to PS DDR(high 2G mem address), the performance is about 400MB, we use ILA to capture the AXI_HP0_FPD port, and find that the ‘axi_wready’ sometime go to '0'
CASE2: SDK
PL send 16KB package to PS DDR(high 2G mem address), the performance is about1900MB, we use ILA to capture the AXI_HP0_FPD port, and find that the ‘axi_wready’ is always '1'
CASE3: only run uboot not load linux image
it seem that after load linux image, the PL to PS DMA performance has been restrict
Is anyone ever had the same situation? How to speed up under linux? Thanks
12-23-2020 02:55 AM
This is expected to have lower performance under linux because the linux OS is managing the memory and creates an overhead.
You might be able to mitigate this by looking at the QoS settings for the DDR controller in the ZU+ TRM UG1085. You can reduce the priority of the OS to the DDR controller and increase the one for the PL
