joancab
PL interrupts in Linux
Is there any general guide to build petalinux for Zynq Us+ with interrupts from PL?
I followed this: Testing UIO with Interrupt on Zynq Ultrascale but didn't work me (error at build).
I think the reason is I don't have an AXI block to generate the interrupt but a counter from a clock. I suppose that is a valid interrupt source.
Tags (3)
joancab
 went back to this problem and found a solution here:
https://forums.xilinx.com/t5/Embedded-Linux/PL-PS-INTERRUPT-on-Ultrazed-on-Petalinux/td-p/925019
And it seems that the right inclusion in the dtsi is:
/include/ "system-conf.dtsi"
    chosen {
        bootargs = "earlycon clk_ignore_unused   uio_pdrv_genirq.of_id=generic-uio";
        stdout-path = "serial0:115200n8";
&<your_hw_ip> {
    compatible = "generic-uio";
Where <your_hw_ip> is the name of the IP block in Vivado.
miker
@joancab
Does your interrupt driver pin from the PL to the PS have the appropriate properties attached?
  • CONFIG.SENSITIVITY = LEVEL_HIGH, LEVEL_LOW, EDGE_FALLING, or EDGE_RISING
  • TYPE = intr
If you have multiple interrupts, you will want to use the "concat" block to concatenate these and this IP will pass the properties appropriately on the output.
Please Reply, Kudos, and Accept as Solution.
joancab
I expected these properties to affect the interrupt input, not the source.
Anyways, my source is a Verilog file dragged to a block diagram, the pin property is 'undef' and not editable in the Properties tab, is that something to set in the verilog file?
miker
@joancab
Here is a quick example I put together when you drive an interrupt (not defined as interrupt in block diagram) and the output applies the CONFIG:SENSITIVITY and TYPE properly.
`timescale 1ns / 1ps
module myIntr (
  input  INTR_IN,
  (* X_INTERFACE_INFO = "XIL_INTERFACENAME INTR_OUT, SENSITIVITY LEVEL_HIGH, PortWidth 1" *)
  (* X_INTERFACE_INFO = "xilinx.com:signal:interrupt:1.0 INTR_OUT INTERRUPT" *)
   output INTR_OUT
assign INTR_OUT = INTR_IN;
endmodule
joancab
I was having a look at the AXI interrupt controller that seems to do that 'conversion' but that looks simpler. I'll give it a go.
First time I see these "directives", I noticed there is a lot in the templates window, good to know.
joancab
That seems to, at least, allow petalinux to build. Next step is the device tree, because I'm not using any AXI peripheral, I added a node (int0) in system-user.dtsi:
    chosen {
	plinterrupt@0{
		interrupt-parent = <&gic>;
		interrupts = <0 112 1>;
After build and boot, I expected to see the interrupt listed by    cat /proc/interrupts, but that doesn't happen.
joancab
    chosen {
&<your_hw_ip> {
