Observer deepakddn
PS EMIO and MIO etherrnet on zcu102
I am trying to implement PS EMIO ethernet as explained in xapp 1305/ 1306. I also want to add MIO ethernet. I  change the patch as in system-user.dtsi as attached here. I am also using the ps_pl_1g.dtsi (attached).
In order to implement MIO application, I changed platform_config.c following as to point to GEM3:
#define PLATFORM_EMAC_BASEADDR XPAR_XEMACPS_1_BASEADDR
I am also applying the patch 0001-fsbl-si570-clk.patch as explained in
http://www.wiki.xilinx.com/PS+and+PL+based+Ethernet+in+Zynq+MPSoC
I still see the errors as:
In:    serial
Out:   serial
Err:   serial
Bootmode: LVL_SHFT_SD_MODE1
Net:   ZYNQ GEM: ff0b0000, phyaddr 9, interface gmii
PHY is not detected
GEM PHY init failed
No ethernet found.
U-BOOT for xilinx-zcu102-2017_3
Can somebody help what else I need to verify GEM0 and GEM3 functioning?
Re: PS EMIO and MIO etherrnet on zcu102
Please refer this forum link which has similar issue that has been resolved:-
https://forums.xilinx.com/t5/Embedded-Linux/How-to-force-U-Boot-to-ignore-GEM0-1-amp-2-and-to-use-GEM3-as/m-p/775849
Best Regards
Shabbir
