PS GEM SGMII not working after reboot
We are using GEM3 of MPSoC with GT Lane 3 connected to a ethernet switch from microchip. When we power on the board, Linux, dsa, and switch drivers work ok and we get two ethernet interfaces from the switch.
The problem begins when we do a "reboot" from linux. The driver reports that the links are up but we cannot ping. We have a reset pin on the switch that we cycle when we reboot and configure the switch again, but no luck.
Don't know if the GT Lane needs some restart or what. We are kind of lost.
Any help would be appreciated.
Re: PS GEM SGMII not working after reboot
Finally, the error was in the ethernet switch from Microchip.
In the Silicon Errata document (module 15), it says that the sgmii interface does not reset with a hardware reset.
http://ww1.microchip.com/downloads/en/DeviceDoc/80000759C.pdf
We tried to reset via switch registers and it did work.
Thanks for the help
The GEM reset can be seen here:
Register 0xFF5E0230 (CRL_APB)
However, I doubt this is the issue.....
Can you also reset the TX and RX engines from network control register.
Bits 2 and 3 – receive and transmit enable.
Just need to clear and set them again.
Reference:
https://www.xilinx.com/html_docs/registers/ug1087/ug1087-zynq-ultrascale-registers.html
At reboot, you closed the higher layers (session, application) managed in software, but probably not (or not completely), at least, the PHY.
As @stephenm suggests, reset the hardware as well. What is worrisome is the driver doesn't handle this... it must. Needs investigation, though, to determine that is the cause.
Thank you very much for the answers. We tried both things but did not have success. Tried to unbind macb for gem3 and switch driver, then reset gem3 and tx-rx, then bind again both drivers and restart network. It didn't work.
We have algo GEM0 through EMIO and a GMII2RGMII core and a external phy. This interface reboots ok, but GEM3 with sgmii and this device tree does not.
&gem3 {
       fixed-link {
       speed = <1000>;
       full-duplex;
Any idea?
Thanks in advance
"connected to an ethernet switch from microchip"  A COTS or your own stuff? Can you try another switch? (the 2nd most popular advice after 'have you tried power cycling?')
The switch is KSZ9897-S from Microchip Technology Inc.
As I mentioned before, the system works fine when we power on the board, but when we reboot from Linux, the interfaces provided by the switch using DSA does not work even though they appear to be ok. We can detect the link up/down if we insert or remove the ethernet cable, but ping does not work for example. The switch has a reset signal that we toggle in the driver with a gpio during initialization. We cannot power cycle only de switch.
The green and orange LEDs only reveal connection in the lower layers, basically, if they negotiated a speed and there is traffic (but that doesn't ensure what is sent will be received, as you are noticing)
One more suggestion, you say you are hard resetting with a GPIO, that sounds fine, just that the switch could need some time to wake up before your thing starts kicking off packets.
Thanks for the help
"does not reset with a hardware reset"
So the hard reset is done in software... omg, Microchip... they used to be good
Good you sorted it out
