PS I2C problems in Linux
Hi All
I am trying to communicate with an I2C  ADC (ADS7828) on my MicroZED board via the supplied Linux (Kernel 3.8).
I am using the I2C-0 on MIO 14 and 15. I have setup the I2C device in Vivado.
I have testet the hardware in standalone, and everything is running fine.
I am running Xilinx 2016.4
My devicetree I2C entry:
ps7_i2c_1: ps7-i2c@e0004000 {
bus-id = <0>;
compatible = "xlnx,ps7-i2c-1.00.a";
i2c-clk = <400000>;
interrupt-parent = <1>;
interrupts = <0 48 4>;
reg = <0xe0004000 0x1000>;
xlnx,has-interrupt = <0x0>;
xlnx,i2c-reset = "<Select>";
#address-cells = <1>;
#size-cells = <0>;
adc@48 {
  compatible = "ADS,ADS7828";
  reg = <0x48>;
I have the entry i dev: /dev/i2c-0 and if I run 'i2cdetect -l' i get:
i2c-0   i2c             XILINX I2C at e0004000                  I2C adapter
My test code:
  printf ("Open\n");
  if ((I2C_Device = open("/dev/i2c-0", O_RDWR)) < 0)
    printf("Cannot Open I2C Master Device\n");
    exit(1);
  printf ("Set address\n");
  if (ioctl (I2C_Device, I2C_SLAVE, ADC_ADDR) < 0)
    printf("Cannot set I2C address\n");
    exit(1);
  printf ("Write\n");
  Adc_Addr = 0x8CU;
  if (write (I2C_Device, &Adc_Addr, 1) != 1)
    printf("I2C write failed\n");
    exit(1);
  close (I2C_Device);
  printf ("Done!\n");
My problem is in Linux, when I try to write a value to the I2C device the code locks up and nothing happens on the pins.
Thanks!
Re: PS I2C problems in Linux
Looks like switch is missing in in device tree.
Could you refer to http://www.wiki.xilinx.com/Cadence+I2C+Driver ?
Praveen
Thanks for the answer!
I have tried:
-Add a switch to the device tree.
-Remove the i2c adc device from the device tree.
Nothing seems to help. I have alsp tried to run
zynq> i2cdetect -r 0
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0 using read byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00:
in both device tree cases, the command locks up and i have to ctrl-c to stop the execution. And nothing happens on the SDA and SCL lines.
