PS-PL communication monitoring from Linux (PS side)
Hi there,
I have a question about how to profile and monitor PL part from the Linux application, one solution might be the AXI performance monitor soft-IP, which still I don't know how it can monitor from Linux side, not standalone (bare-metal). or using ILA might be a solution but still I don't know how can I receive a timing diagram with ILA when I run an application form Linux (Peta-Linux or any other...). when you use Jtag cable for both these monitoring tools you would bypass the effect of Linux part, isn't it?
Consider I have a benchmark, which will be executed in Peta-Linux, and it transfers some data between PS and PL, now I want to extract the timing diagram or any other useful metrics (throughput, ...) from AXI signals and any other e,g. counters in my design based on the time(clock).
bassed on this link, it's not obvious how I can run my application on the Linux side when I plugged JTAG cable and using SDK!
I appreciate your time.
thanks
Hello Amin,
As one solution, you can simply boot your OS through SD card, and the when your system is running, attach the JTAG. Then, open the VIVADO tool, and open the hardware, and auto connect the device. There you can find the ILA (if you have) and monitor any AXI signals from there.
hope this helps!
Farnam
Hello Amin,
hope this helps!
Farnam
Thanks for this quick reply.
solved.
thanks
