Newbie tik0
PTP IEEE 1588 one-step on Zynq UltraScale+ MPSoC causes ptp4l to hang after sending SYNC message
We try to set up one-step-syncing on the Zynq UltraScale+ MPSoC with the Marvell Alaska 88E1512. Please see the configurations, device tree, kernel flags, etc. at the bottom! We setup ptp4l for two-step syncing as explained in [1,2] and everthing works fine even for software and hardware assisted PTP (aka ptp4l -S vs. ptp4l -H). However, whenever we run ptp4l with one-step via the following command `ptp4l -m -l7 -2 -H -E -f /etc/ptp4l.conf -i eth0` (with `phc2sys -s CLOCK_REALTIME -c eth0 -w -r -r` in the background), the program freezes after the first SYNC message (see the output below). If we apply wireshark on a remote client, we see the first announce and sync message coming over the wire as can be seen here:
 After this, ptp4l needs to be killed with `-9` because it is completely frozen.
Do we miss something in the devicetree or in the kernelflags?
Has anyone managed to run one-step syncing on the Zynq?
[1] https://doc.opensuse.org/documentation/leap/tuning/html/book.sle.tuning/cha.tuning.ptp.html#tuning.ptp.ntp2ptp
[2] https://access.redhat.com/documentation/en-us/red_hat_enterprise_linux/6/html/deployment_guide/ch-configuring_ptp_using_ptp4l
Hardware:
  • Zynq UltraScale+ MPSoC xczu9eg-ffvb1156-1-e
  • Marvell Alaska 88E1512
Softwarestack:
Working ptp4l runs (with `phc2sys -s CLOCK_REALTIME -c eth0 -w -r -r` in the background):
  • ptp4l -m -l7 -2 -H -E -i eth0
  • ptp4l -m -l7 -2 -S -E -i eth0
Devicetree entry:
		ethernet@ff0e0000 {
			compatible = "cdns,zynqmp-gem", "cdns,gem";
			status = "okay";
			interrupt-parent = <0x4>;
			interrupts = <0x0 0x3f 0x4 0x0 0x3f 0x4>;
			reg = <0x0 0xff0e0000 0x0 0x1000>;
			clock-names = "pclk", "hclk", "tx_clk", "rx_clk", "tsu_clk";
			#address-cells = <0x1>;
			#size-cells = <0x0>;
			#stream-id-cells = <0x1>;
			iommus = <0x9 0x877>;
			power-domains = <0x11>;
			clocks = <0x3 0x1f 0x3 0x34 0x3 0x30 0x3 0x34 0x3 0x2c>;
			phy-mode = "rgmii-id";
			xlnx,ptp-enet-clock = <0x0>;
			local-mac-address = [00 0a 35 00 22 01];
			phy-handle = <0x12>;
			tsu-clk = <0xee6b280>;
			phy0@1 {
				device_type = "ethernet-phy";
				reg = <0x1>;
				linux,phandle = <0x12>;
				phandle = <0x12>;
ethtool -T eth0 output:
Time stamping parameters for eth0:
Capabilities:
	hardware-transmit     (SOF_TIMESTAMPING_TX_HARDWARE)
	software-transmit     (SOF_TIMESTAMPING_TX_SOFTWARE)
	hardware-receive      (SOF_TIMESTAMPING_RX_HARDWARE)
	software-receive      (SOF_TIMESTAMPING_RX_SOFTWARE)
	software-system-clock (SOF_TIMESTAMPING_SOFTWARE)
	hardware-raw-clock    (SOF_TIMESTAMPING_RAW_HARDWARE)
PTP Hardware Clock: 0
Hardware Transmit Timestamp Modes:
	off                   (HWTSTAMP_TX_OFF)
	on                    (HWTSTAMP_TX_ON)
	one-step-sync         (HWTSTAMP_TX_ONESTEP_SYNC)
Hardware Receive Filter Modes:
	none                  (HWTSTAMP_FILTER_NONE)
	all                   (HWTSTAMP_FILTER_ALL)
KERNELFLAGS via `zcat /proc/config.gz | grep -i "PPS\|PTP\|MACB\|TIMESTAMPING"`:
CONFIG_NET_PTP_CLASSIFY=y
CONFIG_NETWORK_PHY_TIMESTAMPING=y
CONFIG_MACB=y
CONFIG_MACB_USE_HWSTAMP=y
# CONFIG_MACB_PCI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
# CONFIG_PPS_CLIENT_LDISC is not set
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
/etc/ptp4l.conf:
[global]
priority1       127
twoStepFlag       0
`ptp4l -m -l7 -2 -H -E -f /etc/ptp4l.conf -i eth0` output:
$ ptp4l -m -l7 -2 -H -E -f /etc/ptp4l.conf -i eth0
ptp4l[1568.689]: config item (null).assume_two_step is 0
ptp4l[1568.690]: config item (null).check_fup_sync is 0
ptp4l[1568.690]: config item (null).tx_timestamp_timeout is 1
ptp4l[1568.690]: config item (null).clock_servo is 0
ptp4l[1568.690]: config item (null).time_stamping is 1
ptp4l[1568.690]: config item (null).clockClass is 248
ptp4l[1568.690]: config item (null).clockAccuracy is 254
ptp4l[1568.690]: config item (null).offsetScaledLogVariance is 65535
ptp4l[1568.690]: config item (null).productDescription is ';;'
ptp4l[1568.690]: config item (null).revisionData is ';;'
ptp4l[1568.690]: config item (null).userDescription is ''
ptp4l[1568.690]: config item (null).manufacturerIdentity is '00:00:00'
ptp4l[1568.690]: config item (null).domainNumber is 0
ptp4l[1568.690]: config item (null).slaveOnly is 0
ptp4l[1568.690]: config item (null).twoStepFlag is 0
ptp4l[1568.690]: config item (null).priority1 is 127
ptp4l[1568.690]: config item (null).priority2 is 128
ptp4l[1568.691]: config item (null).gmCapable is 1
ptp4l[1568.691]: locked item global.time_stamping as 3
ptp4l[1568.691]: config item (null).free_running is 0
ptp4l[1568.691]: selected /dev/ptp0 as PTP clock
ptp4l[1568.691]: config item (null).uds_address is '/var/run/ptp4l'
ptp4l[1568.691]: section item /var/run/ptp4l.announceReceiptTimeout now 0
ptp4l[1568.691]: section item /var/run/ptp4l.delay_mechanism now 0
ptp4l[1568.691]: section item /var/run/ptp4l.network_transport now 0
ptp4l[1568.691]: section item /var/run/ptp4l.delay_filter_length now 1
ptp4l[1568.691]: config item (null).freq_est_interval is 1
ptp4l[1568.691]: config item (null).kernel_leap is 1
ptp4l[1568.691]: config item (null).timeSource is 160
ptp4l[1568.691]: config item (null).pi_proportional_const is 0.000000
ptp4l[1568.691]: config item (null).pi_integral_const is 0.000000
ptp4l[1568.691]: config item (null).pi_proportional_scale is 0.000000
ptp4l[1568.691]: config item (null).pi_proportional_exponent is -0.300000
ptp4l[1568.692]: config item (null).pi_proportional_norm_max is 0.700000
ptp4l[1568.692]: config item (null).pi_integral_scale is 0.000000
ptp4l[1568.692]: config item (null).pi_integral_exponent is 0.400000
ptp4l[1568.692]: config item (null).pi_integral_norm_max is 0.300000
ptp4l[1568.692]: config item (null).step_threshold is 0.000000
ptp4l[1568.692]: config item (null).first_step_threshold is 0.000020
ptp4l[1568.692]: config item (null).max_frequency is 900000000
ptp4l[1568.692]: config item (null).tsproc_mode is 0
ptp4l[1568.692]: config item (null).delay_filter is 1
ptp4l[1568.692]: config item (null).delay_filter_length is 10
ptp4l[1568.692]: config item (null).summary_interval is 0
ptp4l[1568.692]: config item (null).sanity_freq_limit is 200000000
ptp4l[1568.692]: PI servo: sync interval 1.000 kp 0.700 ki 0.300000
ptp4l[1568.692]: config item /var/run/ptp4l.boundary_clock_jbod is 0
ptp4l[1568.692]: config item /var/run/ptp4l.network_transport is 0
ptp4l[1568.692]: config item /var/run/ptp4l.delayAsymmetry is 0
ptp4l[1568.692]: config item /var/run/ptp4l.follow_up_info is 0
ptp4l[1568.693]: config item /var/run/ptp4l.freq_est_interval is 1
ptp4l[1568.693]: config item /var/run/ptp4l.hybrid_e2e is 0
ptp4l[1568.693]: config item /var/run/ptp4l.path_trace_enabled is 0
ptp4l[1568.693]: config item /var/run/ptp4l.ingressLatency is 0
ptp4l[1568.693]: config item /var/run/ptp4l.egressLatency is 0
ptp4l[1568.693]: config item /var/run/ptp4l.delay_mechanism is 0
ptp4l[1568.693]: config item /var/run/ptp4l.fault_badpeernet_interval is 16
ptp4l[1568.693]: config item /var/run/ptp4l.fault_reset_interval is 4
ptp4l[1568.693]: config item /var/run/ptp4l.tsproc_mode is 0
ptp4l[1568.693]: config item /var/run/ptp4l.delay_filter is 1
ptp4l[1568.693]: config item /var/run/ptp4l.delay_filter_length is 1
ptp4l[1568.693]: config item eth0.boundary_clock_jbod is 0
ptp4l[1568.693]: config item eth0.network_transport is 3
ptp4l[1568.693]: config item eth0.delayAsymmetry is 0
ptp4l[1569.027]: config item eth0.follow_up_info is 0
ptp4l[1569.027]: config item eth0.freq_est_interval is 1
ptp4l[1569.027]: config item eth0.hybrid_e2e is 0
ptp4l[1569.027]: config item eth0.path_trace_enabled is 0
ptp4l[1569.027]: config item eth0.ingressLatency is 0
ptp4l[1569.027]: config item eth0.egressLatency is 0
ptp4l[1569.027]: config item eth0.delay_mechanism is 1
ptp4l[1569.027]: config item eth0.fault_badpeernet_interval is 16
ptp4l[1569.027]: config item eth0.fault_reset_interval is 4
ptp4l[1569.027]: config item eth0.tsproc_mode is 0
ptp4l[1569.027]: config item eth0.delay_filter is 1
ptp4l[1569.027]: config item eth0.delay_filter_length is 10
ptp4l[1569.027]: config item eth0.logMinDelayReqInterval is 0
ptp4l[1569.027]: config item eth0.logAnnounceInterval is 1
ptp4l[1569.027]: config item eth0.announceReceiptTimeout is 3
ptp4l[1569.027]: config item eth0.syncReceiptTimeout is 0
ptp4l[1569.027]: config item eth0.transportSpecific is 0
ptp4l[1569.027]: config item eth0.logSyncInterval is 0
ptp4l[1569.028]: config item eth0.logMinPdelayReqInterval is 0
ptp4l[1569.028]: config item eth0.neighborPropDelayThresh is 20000000
ptp4l[1569.028]: config item eth0.min_neighbor_prop_delay is -20000000
ptp4l[1569.028]: config item eth0.ptp_dst_mac is '01:1B:19:00:00:00'
ptp4l[1569.028]: config item eth0.p2p_dst_mac is '01:80:C2:00:00:0E'
ptp4l[1569.072]: port 1: INITIALIZING to LISTENING on INITIALIZE
ptp4l[1569.072]: config item /var/run/ptp4l.logMinDelayReqInterval is 0
ptp4l[1569.072]: config item /var/run/ptp4l.logAnnounceInterval is 1
ptp4l[1569.072]: config item /var/run/ptp4l.announceReceiptTimeout is 0
ptp4l[1569.072]: config item /var/run/ptp4l.syncReceiptTimeout is 0
ptp4l[1569.072]: config item /var/run/ptp4l.transportSpecific is 0
ptp4l[1569.072]: config item /var/run/ptp4l.logSyncInterval is 0
ptp4l[1569.072]: config item /var/run/ptp4l.logMinPdelayReqInterval is 0
ptp4l[1569.072]: config item /var/run/ptp4l.neighborPropDelayThresh is 20000000
ptp4l[1569.072]: config item /var/run/ptp4l.min_neighbor_prop_delay is -20000000
ptp4l[1569.072]: config item (null).uds_address is '/var/run/ptp4l'
ptp4l[1569.072]: port 0: INITIALIZING to LISTENING on INITIALIZE
ptp4l[1569.072]: interface index 1 is up
ptp4l[1569.072]: interface index 2 is up
ptp4l[1569.073]: port 1: link up
ptp4l[1569.073]: interface index 3 is down
ptp4l[1569.178]: port 0: setting asCapable
ptp4l[1576.023]: port 1: announce timeout
ptp4l[1576.023]: port 1: LISTENING to MASTER on ANNOUNCE_RECEIPT_TIMEOUT_EXPIRES
ptp4l[1576.023]: selected best master clock 5410ec.fffe.64c4ae
ptp4l[1576.023]: assuming the grand master role
ptp4l[1576.024]: port 1: master tx announce timeout
ptp4l[1576.024]: port 1: setting asCapable
ptp4l[1577.023]: port 1: master sync timeout
Re: PTP IEEE 1588 one-step on Zynq UltraScale+ MPSoC causes ptp4l to hang after sending SYNC message
We are facing the same problem with a custom Zynq-Board.
Did you find a solution already?
Michael
