PTP problems on ZCU102
I'm trying to get PTP working on a zcu102 using 2017.3 with a combination of vivado firmware and kernel configuration.
On the software side I believe I have the kernel config and device tree stuff all working, and the only problem now is getting the firmware to output the correct bits.  I know it's the firmware because I can create a "tutorial" project, export the HDF into my petalinux project, and PTP will work.
On the other hand, if I use the production firmware bitstream and HDF, PTP stops working. (PTP timestamps are always zero)
To debug this production firmware, I have the output of the firmware developer who followed https://www.xilinx.com/Attachment/GEM_TSU_Interface_Details_and_IEEE_1588_Support.pdf, opting for using the PS internal IOPLL as the GEM TSU clock. (of the three options for getting the GEM a clock, this seemed easiest).
We can confirm that our setup matches that shown in the guide: "GEM TSU clock" is unchecked in our high-speed peripheral I/O config.  However, PTP still shows timestamps of zero, implying the timestamp register is never incrementing
I would love some tips on how to debug this.  It appears we are doing something in the firmware to muck things up, but I am unclear how to proceed.  Thanks in advance.
And:
Re: PTP problems on ZCU102
We finally solved our problem. It was something in the settings for the GEM_TSU in the output clocks.
