Participant welcomelm
PTP problems on ZCU102
Hi everyone
I was trying to run linuxptp 2.0 on ZCU102, which is running petaLinux 20183, which was compiled by me.
CONFIG_MACB_USE_HWSTAMP is enabled
The kernel is configured to use GEM3
ptp4l throwed the following log
timed out while polling for tx timestamp
Later, when I was debugging kernel
I found that both gem_ptp_txstamp was called but failed at
if (!GEM_BFEXT(DMA_TXVALID, desc->ctrl))
return -EINVAL;
It seems bit 23 of Tx buffer descriptor was never set to indicates a timestamp is captured in the buffer
descriptor
I checked the DMA config register and it was set to 0x70180f10, which means the extended buffer descriptor mode was set.
Can any one share any insight for this?
Min
