PYNQ-Z1 sshfs with Linux Machine on Same network
Hi, I am using PYNQ-Z1 and have connected to the board using my linux machine. I am trying to mount a folder on my linux machine to the fpga board to get pictures data shared on the same network using sshfs but I am getting this error message that fuse device is not found on PYNQ. Please reply on urgent basis. I was able to share a folder from PYNQ to linux by using the commnd on linux machine but on PYNQ when is use the following command i get fuse: device not found. here is the command I am using sshfs babar@192.168.0.100:/home/SharedtoFpga/ /home/xilinx/jupyter_notebooks/Received/ fuse: device not found, try 'modprobe fuse' first
