Parallel Flash erase only one flash
hi , everyone ,I am using the zcu102  Kit RevD, and the source code is xlnx-4.6
the  problem I faced is when I use the tool flash_erase to erase the flashs, it turns out that only half data was erased, I had confirmed the flashs was not in locked status
do any one has the same problem?
