Partitioning SD Card to boot ZC706
I am trying to partition a SD card into boot and root partitions so that I can boot a ZC706 eval board from it.  I have followed the directions posted in the wiki here: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842385/How+to+format+SD+card+for+SD+boot#HowtoformatSDcardforSDboot-RelatedLinks. However, when I have created the 2 partitions and attempt to write and exit I am given the error "Re-reading the partition table failed. : Invalid Arguement"
Is there something I need to do before running fdisk that is resulting in this error?  Or is there a missing step in the directions in the wiki?  Any help is appreciated.
Re: Partitioning SD Card to boot ZC706
The problem I thought I was facing was not actually a problem.  The invalid arguement error I was getting turned out to be a non-issue and formatting was failing simply because I was not using sudo with the format commands.
HI @stephen.lindeman
This steps are proper, I think something going wrong while running the this steps.
Could you please run this script attached script for creating 2 partitions on your sdcard.
Download thsi script & follow below steps.
Connect your SD card to a linux machine.
On your Linux machine open a terminal console.
Run the following command:
sudo fdisk -l
Check the mount for your SD card. Look for /dev/sd*** device which matches the memory card size.
e.g /dev/sdc/ (Disk /dev/sdc: 997 MB, 997720064 bytes)
chmod u+x mkcard-v0.3.sh
sudo ./mkcard-v0.3.sh /dev/sdc
chmod 777 mkcard-v0.3.sh
Thanks & Regards
Aravind
