Passing FSBL results to u-boot on Petalinux 2017.4
OK, so on Petalinux 2017.4 I had a modified fsbl which looked at dip switches on a zc706 board to set the low bits of the Ethernet MAC address. This was then passed from the FSBL to U-Boot using the on-chip RAM and storing a configuration message at address 0xfffffc00. With 2017.4 this no longer seems to work.
I think my FSBL is working because I can see the correct message in the RAM from the u-boot command line using the md command. But if I do a printenv macaddr I still see the default MAC address.
Has this magic address changed for 2017.4? Is there a symbol that I can use rather than the physical address? Or is there a completely different mechanism?
-Pete
Re: Passing FSBL results to u-boot on Petalinux 2017.4
I write the string ethaddr=00:0a:35:00:00:0f to address 0xfffffc00.
But your question got me to wondering how I knew to do that. Which led me to this post https://forums.xilinx.com/t5/Embedded-Linux/MAC-address-EEPROM-Petalinux/td-p/668780. It is clear from here that I had forgotten about the other half of this which is that platform-top.h in the u-boot config headers needs to be modifier to read this location and import the string written there.
#undef CONFIG_PREBOOT
#define CONFIG_PREBOOT	"echo U-BOOT for ${hostname};setenv preboot; echo;env import -t 0xFFFFFC00;dhcp"
So I think that solves the problem. Now the next issue I have is patching the FSBL and getting that to build which is in another post. Now I have to figure out how to patch u-boot as well.
Thanks though. At least I think I have this question answered now.
How are you saving the MAC addr, as I dont think the saveenv is enabled by default in the uboot config
