Visitor l6j6p6
Patching real time linux on Zybo
Hey Guys,
I am trying to install a Preempt_RT patch on the linux. I downloaded the Linux kernel from github which is described in 'Embedded Linux Hands-on Tutorial': https://github.com/DigilentInc/Linux-Digilent-Dev.git . I noticed that the kernel version is 3.18.0, so I install the patch 3.18.24-rt22.patch (since there is no patch for 3.18.0). But when I try to compile the patched kernel with the configuration of full RT, I got this following errors:
 CC      kernel/softirq.o
kernel/softirq.c:1115:13: error: redefinition of 'run_ksoftirqd'
 static void run_ksoftirqd(unsigned int cpu)
kernel/softirq.c:626:13: note: previous definition of 'run_ksoftirqd' was here
kernel/softirq.c: In function 'run_ksoftirqd':
kernel/softirq.c:1123:3: error: implicit declaration of function '__do_softirq' [-Werror=implicit-function-declaration]
   __do_softirq();
kernel/softirq.c: At top level:
kernel/softirq.c:626:13: warning: 'run_ksoftirqd' defined but not used [-Wunused-function]
cc1: some warnings being treated as errors
make[1]: *** [kernel/softirq.o] Error 1
make: *** [kernel] Error 2
So I am wondering how to solve this. And I also wonder which way do you duys choose to run a real time linux on Zybo?
Jimmy
Re: Patching real time linux on Zybo
If those are the only errors it might be easier to fix it. Did u look at trying to update the 3.8 kernel to 3.8.24 before applying the RT patches? Either way there's going to be some work I think and that's the downside of the RT patches in my experience.
John
