Visitor alkoalko
PetaLinux 2.6.20 with MMU support on Spartan3E-1600 Starter Kit
Yes it works...
Here are two issues I figured out when building the linux.bin image on a Ubuntu 8.04  workstation.
Make failed the first time when trying to build mkcramfs. (Missing zlib.h)
I could not figure out, which devel package  I had to install so I installed mkcramfs locally (apt-get) and modified
the Makefile not to build it but use the one from /usr/sbin.
Second issue I ran in, the /bin/sh link pointed to the dash shell. Some string expansions in petalinux-gen-initrd didn't like that, so change the link to /bin/bash and voila, You will get a running linux.bin
Hopefully this will save you some hours...
Re: PetaLinux 2.6.20 with MMU support on Spartan3E-1600 Starter Kit
Thank you very much.
I'm going to try this version these days:)
Observer silva83
   I Know PetaLinux 2.6.20 with MMU suport on Spartan 3E-1600 Starter Kit, but I am not happy: My boss order me implement an linux 2.6 on Spartan 3E-500 Starter Kit!!!!! :(
   Can you said me if I can use PetaLinux 2.6.20 with MMU suport on Spartan 3E-500 Starter Kit or can you help me do all necessary changes to put my board on work!?...
   Thanks and best regards
Observer silva83
Observer silva83
I tried two designs on Base System Builder of EDK10.1 for Spartan-3E 500 Starter kit.
1. Microblaze7.1 50MHz with MMU, No Cache
2. Microblaze7.1 50MHz with MMU, ICache2KB/DCache2KB
Since each design has including the following IP, basic MMULinux works logically.
mpmc4_ddr, debug_module, xps_ethernetlite, xps_gpio(button, led), xps_intc, xps_timer,
xps_uartlite, xps_mch_emc(flash)
However, FPGA utilization of each design as follows, and it may be difficult to add logic further.
Best Regards,
Yoshio Kashiwagi - Nissin Systems
Design Summary:
Number of errors:      0
Number of warnings:  234
Logic Utilization:
  Total Number Slice Registers:       6,087 out of   9,312   65%
    Number used as Flip Flops:        6,086
    Number used as Latches:               1
  Number of 4 input LUTs:             7,044 out of   9,312   75%
Logic Distribution:
  Number of occupied Slices:          4,647 out of   4,656   99%
    Number of Slices containing only related logic:   4,647 out of   4,647 100%
    Number of Slices containing unrelated logic:          0 out of   4,647   0%
      *See NOTES below for an explanation of the effects of unrelated logic.
  Total Number of 4 input LUTs:       7,291 out of   9,312   78%
    Number used as logic:             6,076
    Number used as a route-thru:        247
    Number used as 16x1 RAMs:             4
    Number used for Dual Port RAMs:     722
      (Two LUTs used per Dual Port RAM)
    Number used as Shift registers:     242
  Number of bonded IOBs:                109 out of     232   46%
    IOB Flip Flops:                      92
    IOB Master Pads:                      1
    IOB Slave Pads:                       1
  Number of ODDR2s used:                 22
    Number of DDR_ALIGNMENT = NONE       22
    Number of DDR_ALIGNMENT = C0          0
    Number of DDR_ALIGNMENT = C1          0
  Number of RAMB16s:                     17 out of      20   85%
  Number of BUFGMUXs:                     7 out of      24   29%
  Number of DCMs:                         2 out of       4   50%
  Number of BSCANs:                       1 out of       1  100%
  Number of MULT18X18SIOs:                3 out of      20   15%
Design Summary:
Number of errors:      0
Logic Utilization:
Logic Distribution:
    IOB Flip Flops:                      92
    IOB Master Pads:                      1
    IOB Slave Pads:                       1
Observer silva83
Hi yoshio_kashiwagi,
 I sent some e-mails to e-mail address you gave me, but you don't answer me... Do you receive my e-mails!?... If not, can you confirm your e-mail!?...
 Very good!!! You get two designs on Base System Builter of EDK10.1 for Spartan-3E 500 Starter kit... Can you do me an great favour: send this two designs to my mail box!?... For me it will be an great advance of my studies!!!! Furthermore, You use Windows or Linux Platform to do Kernel Linux with MMU!?...
 Thanks end best regards
It may be the problem of the mail server my company that I cannot find your mail.
Would you send to my HotMail address?
yoshio_kashiwagi(a)live.jp # replace (a) to @
Since each design is the capacity of 10 MBs, I do not have the way of sending to you.
* I was mistaken in the design summary of the non-cache version. :-)
Best Regards,
Design Summary:
Number of errors:      0
Number of warnings:  226
Logic Utilization:
  Total Number Slice Registers:       5,090 out of   9,312   54%
    Number used as Flip Flops:        5,089
  Number of 4 input LUTs:             6,010 out of   9,312   64%
Logic Distribution:
  Number of occupied Slices:          4,397 out of   4,656   94%
    Number of Slices containing only related logic:   4,397 out of   4,397 100%
    Number of Slices containing unrelated logic:          0 out of   4,397   0%
  Total Number of 4 input LUTs:       6,204 out of   9,312   66%
    Number used as logic:             5,296
    Number used as a route-thru:        194
    Number used for Dual Port RAMs:     524
    Number used as Shift registers:     186
    IOB Flip Flops:                      92
    IOB Master Pads:                      1
    IOB Slave Pads:                       1
  Number of RAMB16s:                     10 out of      20   50%
Observer silva83
Hi Yoshio,
   You are a very kind person. Thanks for your answer...
   I suppose that your Hotmail address is the same address you use on msn. I add you on my msn list!... Do you use msn!?...
   My mail address below sending files till 10 Mb... I will send to your e-mail address an invitation to below to that e-mail group... This e-mail is free and have 2 Gbit free to your utilization... An alternative is compact your two projects on 8 Mbit files and send me this files! You can do this, through Winrar program: I send to your e-mail this program... :)
   Best regards and thanks
I sent the private message of this forum to you.
URL of My Internet Storage which placed two designs is shown.
Best Regards,
Newbie wangtianle
Hi Yoshio,
Could you tell me your URL via Email?
My email is wangtianle_ty@126.com.
Best wishes!
