PetaLinux 20115.2 installer fails
Hi all,
I'm running Ubuntu 14.04 with openssl installed. I do the standard petalinux 2015.2 tool installation as sudo, get through the license agreements (just like in 2014.4), and then get this error:
Press Enter to display the license agreements
Do you accept Xilinx End User License Agreement? [y/N] > y
Do you accept Webtalk Terms and Conditions? [y/N] > y
Do you accept Third Party End User License Agreement? [y/N] > y
INFO: Checking installation environment requirements...
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
ERROR: You are missing these development libraries required by PetaLinux:
 - openssl
Please install them with your operating system package manager, and try again
However, openssl is installed and updated. What's going on? Has anyone run into this?
danwwright
Yes "sudo apt-get install libssl-dev" on Ubuntu fixed thde issue.  Thanks!
danwwright
I have the exact same issue.  Ubuntu 14.04 with openssl installed.  But I still get the exact same error about a missing
openssl.
danwwright
dwright@dwright-Studio-XPS-9100:~/Downloads$ sudo ./petalinux-v2015.2-final-installer.run /opt/INFO: Checking installer checksum...
INFO: Extracting PetaLinux installer...
INFO: Installing PetaLinux...
INFO: Checking PetaLinux installer integrity...
INFO: Extracting Installation files...
LICENSE AGREEMENTS
PetaLinux SDK contains software from a number of sources.  Please review
the following licenses and indicate your acceptance of each to continue.
You do not have to accept the licenses, however if you do not then you may
not use PetaLinux SDK.
Use PgUp/PgDn to navigate the license viewer, and press 'q' to close
 - openssl
achutha
@danwwright @vadim_bottomline
This error message indicates that you don’t have the required tools or libraries.In this case it is looking for openssl.
Can you try the details in the link and see if doing the same fix's the issue?
Please let me know if this helps.
Achutha
danwwright
vanmierlo
Mentor
Mentor
Indeed, installing openssl-devel did the trick on CentOS.
achutha
@danwwright @vanmierlo
Thanks for trying the details and updating the thread.
I will publish an answer record on this.
Achutha
hs2
@achutha
You should add this information to the answer record resp. create a new one.
Thanks, HS2
achutha
@hs2
I have created an Answer record and will request to publish it.
Achutha
@achutha
Thanks for the timely answer record, this will help people out. Glad I could report something that affects others...
Is there a way to rename the subject of the thread? I had a typo, an extra "1".
eneserdin
While installing PetaLinux 2016.3 on my Ubuntu 16.04 also I got the ncurses error. Looking at the solutions I installed development package for ncurses. It installed.
FYI
ram14
try this command
