PetaLinux 2013.10 - SDK Integration
I don't see a "Eclipse Plugin Guide" for 2013.10. Did we lose this feature in 2013.10, or can we follow the 2013.4 Guide?
Yes, I am working through those. For those folks just trying out the new PetaLinux tool (2013.10), it should be noted that the project structures and (possibly) work flows are radically different from PetaLinux 2013.4. I like the fact that the tools are now separate from the project files themselves, and that (apparently) each project carries its own full linux source tree.
Is there a high-level overview of the project layout and flow changes between 2013.4 and 2013.10? Given the magnitude of the changes, I would think that this would be incredibly useful to many Xilinx tool users.
The PetaLinux SDK 2013.10 release does not include the Eclipse GUI plugin like previous releases.  Please consult the PetaLinux SDK Getting Started Guide (UG977) and PetaLinux SDK Board Bringup Guide (UG980) for details on how to use the PetaLinux SDK tools without theGUI.
My apologies...it looks like these are covered in UG977 (Getting Started). I'll read through the entire document this time :-)
