Observer raymond.walter
PetaLinux 2017.1 Custom Device Tree
Hey,
I'm currently moving my ZynqMP project from PetaLinux 2016.4 to 2017.1 and I've run into a problem regarding editing the device tree.
The method I used in my 2016.4 project was to create a .bbappend to the device tree generation script and put my modified device tree into the files folder (as described here).
This no longer works. I'm always getting the default device tree and my custom device tree isn't even parsed.
Has anyone found a solution to this? Is there another way to do this in 2017.1?
Thanks in advance!
Raymond
Re: PetaLinux 2017.1 Custom Device Tree
Hi @raymond.walter
The suggested way to customize the devicetree file in petalinux 2017.1 is using the system-user.dtsi file within the meta-user layer as pointed by UG1144.
So the devicetree generation tool should map those IPs included in your design HDF and system-user.dtsi should be used to modify those nodes or to add board level nodes.
Ibai
Hi @raymond.walter
Ibai
