Visitor ayazdi
PetaLinux 2017.3 build problem for Kintex 5
I'm trying to build a PetaLinux for a Kintex5 system (KC705) with DDR3 and UART Lite.  After sucessfully compiling the bitstream file in Vivado, I create and configure a petalinux project using the generated hardware by Vivado. But every time I try to build the Petalinux, I get and error when the system tries to generate mba_fs_boot. Any ideas what's going on?
Please see the error below:
DEBUG: Executing python function sysroot_cleansstate
DEBUG: Python function sysroot_cleansstate finished
DEBUG: Executing shell function do_configure
MISC_ARG is -yamlconf /home/alireza/codes/2017/Vivado/Ethernet/uBlaze/penta_linux/PentaLinux4uBlaze/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.yaml -yamlconf /home/alireza/codes/2017/Vivado/Ethernet/uBlaze/penta_linux/PentaLinux4uBlaze/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.yaml
APP_ARG is -app "mba_fs_boot"
cmd is: xsct /home/alireza/codes/2017/Vivado/Ethernet/uBlaze/penta_linux/PentaLinux4uBlaze/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.tcl -ws /home/alireza/codes/2017/Vivado/Ethernet/uBlaze/penta_linux/PentaLinux4uBlaze/build/../components/plnx_workspace/fsboot -pname fs-boot -rp /opt/Xilinx/PentaLinux/tools/hsm/data/embeddedsw -processor microblaze_0 -hdf /home/alireza/codes/2017/Vivado/Ethernet/uBlaze/penta_linux/PentaLinux4uBlaze/build/tmp/deploy/images/plnx_microblaze/Xilinx-plnx_microblaze.hdf -arch 32 -app "mba_fs_boot" -yamlconf /home/alireza/codes/2017/Vivado/Ethernet/uBlaze/penta_linux/PentaLinux4uBlaze/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.yaml -yamlconf /home/alireza/codes/2017/Vivado/Ethernet/uBlaze/penta_linux/PentaLinux4uBlaze/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.yaml
WARNING: [Hsi 55-1434] Error /opt/Xilinx/PentaLinux/tools/hsm/data/embeddedsw/XilinxProcessorIPLib/drivers/rfdc_v2_1/data/rfdc.mdd:49 Unrecognized Option name. List of possible Option names are : DRC, DESC, COPYFILES, DEPENDS, SUPPORTED_PERIPHERALS, DRIVER_STATE, DEFAULT_OS, NAME, VERSION
INFO: [Hsi 55-1698] elapsed time for repository loading 0 seconds
hsi::set_repo_path: Time (s): cpu = 00:00:00.06 ; elapsed = 00:00:05 . Memory (MB): peak = 330.285 ; gain = 1.035 ; free physical = 273 ; free virtual = 31490
/opt/Xilinx/PentaLinux/tools/hsm/gnu/microblaze/lin
ERROR: [Common 17-55] 'get_property' expects at least one object.
Resolution: If [get_<value>] was used to populate the object, check to make sure this command returns at least one valid object.
ERROR: [Hsi 55-1545] Problem running tcl command swapp_mba_fs_boot::swapp_generate : ERROR: [Common 17-55] 'get_property' expects at least one object.
while executing
"common::get_property IP_NAME [get_cells $instance]"
(procedure "get_ipname" line 2)
invoked from within
"get_ipname $flash"
(procedure "get_flash_config" line 5)
invoked from within
"get_flash_config $fid"
(procedure "swapp_mba_fs_boot::swapp_generate" line 7)
invoked from within
ERROR: [Hsi 55-1438] Error running generate_app.
Failed to generate app mba_fs_boot
while executing
"error "Failed to generate app $params(app)""
invoked from within
"if { [catch {hsi generate_app -dir $project} res] } {
(file "/home/alireza/codes/2017/Vivado/Ethernet/uBlaze/penta_linux/PentaLinux4uBlaze/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c..." line 35)
WARNING: exit code 1 from a shell command.
ERROR: Function failed: do_configure (log file is located at  .... )
Visitor tiantianxch
Re: PetaLinux 2017.3 build problem for Kintex 5
the same to vcu118: see below:
~/project/vcu118$ petalinux-build -c u-boot
[INFO] building u-boot
[INFO] sourcing bitbake
INFO: bitbake virtual/bootloader
Loading cache: 100% |##########################################################################################################################################################################################################################################| Time: 0:00:01
Loaded 3257 entries from dependency cache.
Parsing recipes: 100% |########################################################################################################################################################################################################################################| Time: 0:00:02
Parsing of 2466 .bb files complete (2432 cached, 34 parsed). 3259 targets, 553 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#####################################################################################################################################################################################################################################| Time: 0:00:08
Checking sstate mirror object availability: 100% |#############################################################################################################################################################################################################| Time: 0:00:09
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: fs-boot-2017.3+gitAUTOINC+3c9f0cfde9-r0 do_configure: Function failed: do_configure (log file is located at /home/user/project/vcu118/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/temp/log.do_configure.8780)
ERROR: Logfile of failure stored in: /home/user/project/vcu118/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/temp/log.do_configure.8780
the log is:
MISC_ARG is -yamlconf /home/user/project/vcu118/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.yaml -yamlconf /home/user/project/vcu118/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.yaml
cmd is: xsct /home/user/project/vcu118/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.tcl -ws /home/user/project/vcu118/build/../components/plnx_workspace/fsboot -pname fs-boot -rp /home/user/eda/xilinx/petalinux-v2017.3-final/tools/hsm/data/embeddedsw -processor microblaze_0 -hdf /home/user/project/vcu118/build/tmp/deploy/images/plnx_microblaze/Xilinx-plnx_microblaze.hdf -arch 32 -app "mba_fs_boot" -yamlconf /home/user/project/vcu118/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.yaml -yamlconf /home/user/project/vcu118/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.yaml
WARNING: [Hsi 55-1434] Error /home/user/eda/xilinx/petalinux-v2017.3-final/tools/hsm/data/embeddedsw/XilinxProcessorIPLib/drivers/rfdc_v2_1/data/rfdc.mdd:49 Unrecognized Option name. List of possible Option names are : DRC, DESC, COPYFILES, DEPENDS, SUPPORTED_PERIPHERALS, DRIVER_STATE, DEFAULT_OS, NAME, VERSION
INFO: [Hsi 55-1698] elapsed time for repository loading 1 seconds
/home/user/eda/xilinx/petalinux-v2017.3-final/tools/hsm/gnu/microblaze/lin
while executing
invoked from within
"get_ipname $flash"
invoked from within
invoked from within
while executing
invoked from within
(file "/home/user/project/vcu118/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/fsboot.tcl" line 35)
ERROR: Function failed: do_configure (log file is located at /home/user/project/vcu118/build/tmp/work/plnx_microblaze-xilinx-linux/fs-boot/2017.3+gitAUTOINC+3c9f0cfde9-r0/temp/log.do_configure.8780)
Looks like the build is failing while creating the app. Have you the flash added?
Can you post the HDF?
Visitor tiantianxch
We had post the HDF,but we have no flash.
Can you add the linear flash to your HW and try again? If you are using the KC705, there should be a board tab in the vivado, you can click and drop this into your BD, and re-export to SDK
Dear all,
same issue here, even with linear or spi flash...
hw : kc705
vivado 17.3
petatlinux-build -c fs-boot hang on "Failed to generate app"
|     while executing
|     invoked from within
| "get_ipname $flash"
So, some background. The meta-xilinx-tools layers (which is used in Petalinux), will call the recipes-bsp/fsboot. Here there is an app.tcl to create the app. The app is created via mba_fs_boot.tcl. The offending piece of code is seen here:
proc get_flash_config { fp } {
set ipname "";
set flash [get_flash_mem];
if {$flash ne ""} {
set ipname [get_ipname $flash];
What your error message is saying is "get_property expects at least one object". There is a trace dump of where this occurs in the tcl code. If we look at the get_ipname. it indeed points to the get_property.
proc get_ipname { instance } {
set ipname [common::get_property IP_NAME [get_cells $instance]];
return $ipname;
So, it is here that it is failing. So, the get_cells $instance is blank, hense this will fail. So, we would need to investigate why.
Can you send me your HDF, and I can test this real quick?
thank you for your commitment, here is my hdf
flash is kc705 emc
I took your HDF. I noticed your instruction memory is located at 0x4000. However, the Base Vector of the Microblaze is set to 0x0. The MB will expect instructions at the base vector (0x0) upon coming out of reset. So, this is wrong. I have fixed this. I also noticed some floating ports (spi). I removed these, and re-generated the output products, and re-exported to SDK to create the HDF. I used this HDF in petalinux 2017.3 to create the project. This work for me:
You can build the BD using the attached TCL
Also, there is a KC705 BSP that you can use in Petalinux. You can get this from below
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
