PetaLinux 2018.2 - DNF repositories
If I understood correctly from the Xilinx Wiki pages, the Smart package manager was replaced by DNF.
I built PetaLinux for Ultra96. The dnf is installed, but apparently has no repositories configured:
root@xilinx-ultra96-reva-2018_2:~# dnf repolist
No repositories available
Are there any official repositories that could be used with dnf?
Or, if not, can PetaLinux configured to use the smart package manager instead of dnf? (The factory Ultra96 SD card comes with smart package manager)
Attila
Voyager
Voyager
Re: PetaLinux 2018.2 - DNF repositories
Could you check the following in your target board?
root@ultra96:~# cat /etc/yum.repos.d/oe-remote-repo.repo
[oe-remote-repo]
name=OE Remote Repo:
baseurl=http://192.168.7.1:5678
gpgcheck=0
If threre is no such file, add  the following to project-spec/meta-user/conf/petalinuxbsp.conf
PACKAGE_FEED_URIS = "http://192.168.7.1:5678"
PACKAGE_FEED_URIS is uri of host which has rpm repository.
Thanks @hokim. I think I will use the RPM repos that are used in the official Ultra96 repos too:
root@Ultra96:~# smart channel --show
[url0-aarch64]
type = rpm-md
priority = 20
baseurl = http://petalinux.xilinx.com/sswreleases/sswboardfeeds/zzsoc/aarch64
[url0-all]
type = rpm-md
priority = 15
baseurl = http://petalinux.xilinx.com/sswreleases/sswboardfeeds/zzsoc/all
[ulr0-plnx_aarch64]
type = rpm-md
baseurl = http://petalinux.xilinx.com/sswreleases/sswboardfeeds/zzsoc/plnx_aarch64
[rpmsys]
type = rpm-sys
Cheers,
Attila
Voyager
Voyager
Do you mean the above urls are  petalinux rpm repositories provided by xilinx?
I'm using package manage system only for my rpms built by petalinux-build
Hey
do you solve this problem? I confront the same problem. do not know how to solve it .
thanks
