PetaLinux 2018.3 add meta-xilinx-tsn layer
Hi all,
I am trying to add the meta-xilinx-tsn layer (version 2018.3) to a Petalinux project also made in 2018.3.  I have followed the steps of ug1144-petalinux-tools-reference-guide.pdf, but after adding the layer on petalinux-config, when I save and close the config, the next error appears:
[INFO] generating Kconfig for project
[INFO] menuconfig project
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] sourcing bitbake
ERROR: Failed to source bitbake
ERROR: Failed to config project.
What can be the problem?
Re: PetaLinux 2018.3 add meta-xilinx-tsn layer
Hi alejandro@erlerobotics.com
I doubut your project got closed in between when it is configuring.
Can you please clean the project & rebuild once.
petalinux-build -x mrproper   -- This will clean the project.
petalinux-config
petalinux-build
I hope ypu reffrered ug1144 guide,section : "Adding a Recipe from Yocto e-SDK Layers to
petalinux-image-full.bb"
Thanks &  regards
Aravind
Thanks for your response,
First of all, I added the layer using petalinux-config, and I was able to add it. I was able to launch a petalinux 2018.3 system before adding the meta-xilinx-tsn layer, but now I am facing problems with the new u-boot and image.ub files created, so I may have not configured properly the petalinux build. Being more precise, I make the BOOT.BIN file following the ug1144 with the command, without any pmufw.
petalinux-package --boot --fsbl <FSBL image> --fpga <FPGA bitstream> --pmufw <PATH_TO_PMU_FW_ELF> --u-boot
Then I create the uImage
petalinux-package --image -c kernel --format uImage
I program the BOOT.BIN and the uImage
program_flash -f BOOT.BIN -offset 0 -flash_type qspi_single -fsbl zynq_fsbl.elf -cable type xilinx_tcf url TCP:127.0.0.1:3121
program_flash -f uImage.bin -offset 0x520000 -flash_type qspi_single -fsbl zynq_fsbl.elf -cable type xilinx_tcf url TCP:127.0.0.1:3121
When I had not included the new layer, I could boot the system with this command
sf probe 0 8000000 0;sf read 0x2080000 0x520000;bootm 0x2080000
But now when I execute it i get the next error
## Booting kernel from Legacy Image at 02080000 ...
   Image Name:   Linux-4.14.0-xilinx-v2018.3
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    2086488 Bytes = 2 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
FDT and ATAGS support not compiled in - hanging
### ERROR ### Please RESET the board ###
How can I fix it? I have tried cleaning and rebuilding the project. The board is ok, it works with tested boot.bin and image.ub from version 2018.1.
I did not find the "Adding a Recipe from Yocto e-SDK Layers to petalinux-image-full.bb" section in the ug1144 guide. Could you extend the information on that section?
Alex
