Observer qglyj
PetaLinux 2018.3 fails to fetch files when petalinux build
 there is packagegroup-petalinux-x11 in my rootfs ,when i build the project,sometime there is erro log like :
ERROR: libpcap-1.8.1-r0 do_package_qa_setscene: Fetcher failure: Unable to find file file://04/sstate:libpcap:aarch64-xilinx-linux:1.8.1:r0:aarch64:3:0473ec10eda82bcaf73423cbfe01054a_package_qa.tgz;downloadfilename=04/sstate:libpcap:aarch64-xilinx-linux:1.8.1:r0:aarch64:3:0473ec10eda82bcaf73423cbfe01054a_package_qa.tgz anywhere. The paths that were searched were:
    /opt/Xilinx/projects/xilinx-ultra96-reva-2018.3/build/sstate-cache
when i remove  packagegroup-petalinux-x11 in my rootfs ,the error disapper,is this bug?
Re: PetaLinux 2018.3 fails to fetch files when petalinux build
Hi @qglyj ,
Have you ran below command?
petalinux-build -x distclean
Best Regards
Kranthi
Observer qglyj
thank you for your reply,after i do this and petalinux-build ,the log is :
ERROR: xcursor-transparent-theme-0.1.1+gitAUTOINC+23c8af5ba4-r0 do_package_write_rpm_setscene: No suitable staging                 package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/all-xilinx-linux/xcursor-transparent-theme/0.1.1+gitAUTOINC+23c8af5ba4-r0/temp/log.do_package_write_rpm                _setscene.26781
ERROR: packagegroup-petalinux-x11-1.0-r0 do_package_qa_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/all-xilinx-linux/packagegroup-petalinux-x11/1.0-r0/temp/log.do_package_qa_setscene.26786
ERROR: xtscal-0.6.3-r13 do_populate_lic_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/xtscal/0.6.3-r13/temp/log.do_populate_lic_setscene.26782
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-graphics/xcursor-transparent-theme/xcursor-transparent-theme_git.bb:do_package_write_rpm_setscene) failed with                 exit code '1' - real task will be run instead
ERROR: xcursor-transparent-theme-0.1.1+gitAUTOINC+23c8af5ba4-r0 do_populate_lic_setscene: No suitable staging packa                ge found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/all-xilinx-linux/xcursor-transparent-theme/0.1.1+gitAUTOINC+23c8af5ba4-r0/temp/log.do_populate_lic_sets                cene.26784
ERROR: libxcalibrate-0.0+gitAUTOINC+209d83af61-r0 do_package_write_rpm_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/libxcalibrate/0.0+gitAUTOINC+209d83af61-r0/temp/log.do_package_write_rpm_setscene.                26783
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembe                dded/meta-oe/recipes-graphics/xtscal/xtscal_0.6.3.bb:do_populate_lic_setscene) failed with exit code '1' - real tas                k will be run instead
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-petalinu                x/recipes-core/packagegroups/packagegroup-petalinux-x11.bb:do_package_qa_setscene) failed with exit code '1' - real                 task will be run instead
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-graphics/xcursor-transparent-theme/xcursor-transparent-theme_git.bb:do_populate_lic_setscene) failed with exit                 code '1' - real task will be run instead
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-graphics/xorg-lib/libxcalibrate_git.bb:do_package_write_rpm_setscene) failed with exit code '1' - real task wi                ll be run instead
ERROR: xcursor-transparent-theme-0.1.1+gitAUTOINC+23c8af5ba4-r0 do_populate_sysroot_setscene: No suitable staging p                ackage found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/all-xilinx-linux/xcursor-transparent-theme/0.1.1+gitAUTOINC+23c8af5ba4-r0/temp/log.do_populate_sysroot_                setscene.26788
ERROR: xtscal-0.6.3-r13 do_package_write_rpm_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/xtscal/0.6.3-r13/temp/log.do_package_write_rpm_setscene.26787
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembe                dded/meta-oe/recipes-graphics/xtscal/xtscal_0.6.3.bb:do_package_write_rpm_setscene) failed with exit code '1' - rea                l task will be run instead
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-graphics/xcursor-transparent-theme/xcursor-transparent-theme_git.bb:do_populate_sysroot_setscene) failed with                 exit code '1' - real task will be run instead
ERROR: packagegroup-petalinux-x11-1.0-r0 do_package_write_rpm_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/all-xilinx-linux/packagegroup-petalinux-x11/1.0-r0/temp/log.do_package_write_rpm_setscene.26789
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-petalinu                x/recipes-core/packagegroups/packagegroup-petalinux-x11.bb:do_package_write_rpm_setscene) failed with exit code '1'                 - real task will be run instead
ERROR: xcursor-transparent-theme-0.1.1+gitAUTOINC+23c8af5ba4-r0 do_package_qa_setscene: No suitable staging package                 found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/all-xilinx-linux/xcursor-transparent-theme/0.1.1+gitAUTOINC+23c8af5ba4-r0/temp/log.do_package_qa_setsce                ne.26791
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-graphics/xcursor-transparent-theme/xcursor-transparent-theme_git.bb:do_package_qa_setscene) failed with exit c                ode '1' - real task will be run instead
ERROR: libxcalibrate-0.0+gitAUTOINC+209d83af61-r0 do_package_qa_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/libxcalibrate/0.0+gitAUTOINC+209d83af61-r0/temp/log.do_package_qa_setscene.26792
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-graphics/xorg-lib/libxcalibrate_git.bb:do_package_qa_setscene) failed with exit code '1' - real task will be r                un instead
ERROR: xf86-video-armsoc-2_1.4.1+gitAUTOINC+8bbdb2ae3b-r0 do_packagedata_setscene: No suitable staging package foun                d
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/xf86-video-armsoc/2_1.4.1+gitAUTOINC+8bbdb2ae3b-r0/temp/log.do_packagedata_setscen                e.26790
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-xilinx/m                eta-xilinx-bsp/recipes-graphics/xorg-driver/xf86-video-armsoc_git.bb:do_packagedata_setscene) failed with exit code                 '1' - real task will be run instead
ERROR: xtscal-0.6.3-r13 do_packagedata_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/xtscal/0.6.3-r13/temp/log.do_packagedata_setscene.26800
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0/te                mp/log.do_package_write_rpm_setscene.26785
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembe                dded/meta-oe/recipes-support/opencv/opencv_3.3.bb:do_package_write_rpm_setscene) failed with exit code '1' - real t                ask will be run instead
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembe                dded/meta-oe/recipes-graphics/xtscal/xtscal_0.6.3.bb:do_packagedata_setscene) failed with exit code '1' - real task                 will be run instead
ERROR: xcursor-transparent-theme-0.1.1+gitAUTOINC+23c8af5ba4-r0 do_packagedata_setscene: No suitable staging packag                e found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/all-xilinx-linux/xcursor-transparent-theme/0.1.1+gitAUTOINC+23c8af5ba4-r0/temp/log.do_packagedata_setsc                ene.26801
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-graphics/xcursor-transparent-theme/xcursor-transparent-theme_git.bb:do_packagedata_setscene) failed with exit                 code '1' - real task will be run instead
ERROR: libxcalibrate-0.0+gitAUTOINC+209d83af61-r0 do_packagedata_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/libxcalibrate/0.0+gitAUTOINC+209d83af61-r0/temp/log.do_packagedata_setscene.26809
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-graphics/xorg-lib/libxcalibrate_git.bb:do_packagedata_setscene) failed with exit code '1' - real task will be                 run instead
ERROR: libxcalibrate-0.0+gitAUTOINC+209d83af61-r0 do_populate_sysroot_setscene: No suitable staging package found
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/libxcalibrate/0.0+gitAUTOINC+209d83af61-r0/temp/log.do_populate_sysroot_setscene.2                6810
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-graphics/xorg-lib/libxcalibrate_git.bb:do_populate_sysroot_setscene) failed with exit code '1' - real task wil                l be run instead
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/gstreamer1.0-plugins-base/1.12.2+gitAUTOINC+71745a77db-r0/temp/log.do_package_writ                e_rpm_setscene.26793
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-multimedia/gstreamer/gstreamer1.0-plugins-base_1.12.2.bb:do_package_write_rpm_setscene) failed with exit code                 '1' - real task will be run instead
ERROR: opencv-3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0 do_packagedata_setscene: Err                or executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
     0001:
 *** 0002:do_packagedata_setscene(d)
     0003:
File: '/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/classes/package.bbcl                ass', lineno: 2184, function: do_packagedata_setscene
     2180:do_packagedata[sstate-lockfile-shared] = "${PACKAGELOCK}"
     2181:do_packagedata[stamp-extra-info] = "${MACHINE}"
     2182:
     2183:python do_packagedata_setscene () {
 *** 2184:    sstate_setscene(d)
     2185:}
     2186:addtask do_packagedata_setscene
     2187:
     2188:#
File: '/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/classes/sstate.bbcla                ss', lineno: 681, function: sstate_setscene
     0677:            break
     0678:
     0679:def sstate_setscene(d):
     0680:    shared_state = sstate_state_fromvars(d)
 *** 0681:    accelerate = sstate_installpkg(shared_state, d)
     0682:    if not accelerate:
     0683:        bb.fatal("No suitable staging package found")
     0684:
     0685:python sstate_task_prefunc () {
File: '/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/classes/sstate.bbcla                ss', lineno: 328, function: sstate_installpkg
     0324:    for f in (d.getVar('SSTATEPREINSTFUNCS') or '').split() + ['sstate_unpack_package']:
     0325:        # All hooks should run in the SSTATE_INSTDIR
     0326:        bb.build.exec_func(f, d, (sstateinst,))
     0327:
 *** 0328:    return sstate_installpkgdir(ss, d)
     0329:
     0330:def sstate_installpkgdir(ss, d):
     0331:    import oe.path
     0332:    import subprocess
File: '/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/classes/sstate.bbcla                ss', lineno: 350, function: sstate_installpkgdir
     0346:        oe.path.remove(dir)
     0347:
     0348:    for state in ss['dirs']:
     0349:        prepdir(state[1])
 *** 0350:        os.rename(sstateinst + state[0], state[1])
     0351:    sstate_install(ss, d)
     0352:
     0353:    for plain in ss['plaindirs']:
     0354:        workdir = d.getVar('WORKDIR')
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/ai/jiangkai/zcu102/petalinux2018_prj/prj_                mtcnn_mobilefacenet/build/tmp/work/aarch64-xilinx-linux/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4                206aef_fccf7cd6a4-r0/sstate-install-packagedata/pkgdata' -> '/home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_m                obilefacenet/build/tmp/work/aarch64-xilinx-linux/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_                fccf7cd6a4-r0/pkgdata'
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0/te                mp/log.do_packagedata_setscene.26808
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembe                dded/meta-oe/recipes-support/opencv/opencv_3.3.bb:do_packagedata_setscene) failed with exit code '1' - real task wi                ll be run instead
ERROR: tbb-20170412+AUTOINC+a2cfdfe946-r0 do_populate_sysroot_setscene: Error executing a python function in exec_p                ython_func() autogenerated:
     0001:
 *** 0002:do_populate_sysroot_setscene(d)
     0003:
File: '/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/classes/staging.bbcl                ass', lineno: 126, function: do_populate_sysroot_setscene
     0122:do_populate_sysroot[sstate-outputdirs] = "${COMPONENTS_DIR}/${PACKAGE_ARCH}/${PN}"
     0123:do_populate_sysroot[sstate-fixmedir] = "${COMPONENTS_DIR}/${PACKAGE_ARCH}/${PN}"
     0124:
     0125:python do_populate_sysroot_setscene () {
 *** 0126:    sstate_setscene(d)
     0127:}
     0128:addtask do_populate_sysroot_setscene
     0129:
     0130:def staging_copyfile(c, target, dest, postinsts, seendirs):
     0677:            break
     0678:
     0684:
     0327:
     0329:
     0347:
     0352:
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/ai/jiangkai/zcu102/petalinux2018_prj/prj_                mtcnn_mobilefacenet/build/tmp/work/aarch64-xilinx-linux/tbb/20170412+AUTOINC+a2cfdfe946-r0/sstate-install-populate_                sysroot/sysroot-destdir' -> '/home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/tmp/work/aarc                h64-xilinx-linux/tbb/20170412+AUTOINC+a2cfdfe946-r0/sysroot-destdir'
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/tbb/20170412+AUTOINC+a2cfdfe946-r0/temp/log.do_populate_sysroot_setscene.26836
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembe                dded/meta-oe/recipes-support/tbb/tbb.bb:do_populate_sysroot_setscene) failed with exit code '1' - real task will be                 run instead
ERROR: v4l-utils-1.12.3-r0 do_packagedata_setscene: Error executing a python function in exec_python_func() autogen                erated:
     0001:
     0003:
     2182:
     2185:}
     2187:
     2188:#
     0677:            break
     0678:
     0684:
     0327:
     0329:
     0347:
     0352:
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/ai/jiangkai/zcu102/petalinux2018_prj/prj_                mtcnn_mobilefacenet/build/tmp/work/aarch64-xilinx-linux/v4l-utils/1.12.3-r0/sstate-install-packagedata/pkgdata' ->                 '/home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/tmp/work/aarch64-xilinx-linux/v4l-utils/1                .12.3-r0/pkgdata'
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/v4l-utils/1.12.3-r0/temp/log.do_packagedata_setscene.26837
ERROR: v4l-utils-1.12.3-r0 do_populate_sysroot_setscene: Error executing a python function in exec_python_func() au                togenerated:
     0001:
     0003:
     0124:
     0127:}
     0129:
     0677:            break
     0678:
     0684:
     0327:
     0329:
     0347:
     0352:
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/ai/jiangkai/zcu102/petalinux2018_prj/prj_                mtcnn_mobilefacenet/build/tmp/work/aarch64-xilinx-linux/v4l-utils/1.12.3-r0/sstate-install-populate_sysroot/sysroot                -destdir' -> '/home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/tmp/work/aarch64-xilinx-linu                x/v4l-utils/1.12.3-r0/sysroot-destdir'
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/v4l-utils/1.12.3-r0/temp/log.do_populate_sysroot_setscene.26835
ERROR: libwebp-0.6.0-r0 do_packagedata_setscene: Error executing a python function in exec_python_func() autogenera                ted:
     0001:
     0003:
     2182:
     2185:}
     2187:
     2188:#
     0677:            break
     0678:
     0684:
     0327:
     0329:
     0347:
     0352:
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/ai/jiangkai/zcu102/petalinux2018_prj/prj_                mtcnn_mobilefacenet/build/tmp/work/aarch64-xilinx-linux/libwebp/0.6.0-r0/sstate-install-packagedata/pkgdata' -> '/h                ome/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/tmp/work/aarch64-xilinx-linux/libwebp/0.6.0-                r0/pkgdata'
WARNING: Logfile for failed setscene task is /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/bui                ld/tmp/work/aarch64-xilinx-linux/libwebp/0.6.0-r0/temp/log.do_packagedata_setscene.26838
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembe                dded/meta-oe/recipes-multimedia/v4l2apps/v4l-utils_1.12.3.bb:do_populate_sysroot_setscene) failed with exit code '1                ' - real task will be run instead
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembe                dded/meta-oe/recipes-multimedia/v4l2apps/v4l-utils_1.12.3.bb:do_packagedata_setscene) failed with exit code '1' - r                eal task will be run instead
WARNING: Setscene task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/rec                ipes-multimedia/webp/libwebp_0.6.0.bb:do_packagedata_setscene) failed with exit code '1' - real task will be run in                stead
NOTE: Executing RunQueue Tasks
ERROR: libwebp-0.6.0-r0 do_fetch: Network access disabled through BB_NO_NETWORK (or set indirectly due to use of BB                _FETCH_PREMIRRORONLY) but access requested with command /usr/bin/env wget -t 2 -T 30 -nv --passive-ftp --no-check-c                ertificate -P /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/downloads 'http://petalinux.                xilinx.com/sswreleases/rel-v2018.3/downloads/libwebp-0.6.0.tar.gz' (for url http://petalinux.xilinx.com/sswreleases                /rel-v2018.3/downloads/libwebp-0.6.0.tar.gz)
ERROR: libwebp-0.6.0-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/tmp/w                ork/aarch64-xilinx-linux/libwebp/0.6.0-r0/temp/log.do_fetch.26926
ERROR: Task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/recipes-multim                edia/webp/libwebp_0.6.0.bb:do_fetch) failed with exit code '1'
ERROR: v4l-utils-1.12.3-r0 do_fetch: Network access disabled through BB_NO_NETWORK (or set indirectly due to use of                 BB_FETCH_PREMIRRORONLY) but access requested with command /usr/bin/env wget -t 2 -T 30 -nv --passive-ftp --no-chec                k-certificate -P /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/downloads 'http://petalin                ux.xilinx.com/sswreleases/rel-v2018.3/downloads/v4l-utils-1.12.3.tar.bz2' (for url http://petalinux.xilinx.com/sswr                eleases/rel-v2018.3/downloads/v4l-utils-1.12.3.tar.bz2)
ERROR: v4l-utils-1.12.3-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/tmp/w                ork/aarch64-xilinx-linux/v4l-utils/1.12.3-r0/temp/log.do_fetch.26927
ERROR: tbb-20170412+AUTOINC+a2cfdfe946-r0 do_fetch: Network access disabled through BB_NO_NETWORK (or set indirectl                y due to use of BB_FETCH_PREMIRRORONLY) but access requested with command /usr/bin/env wget -t 2 -T 30 -nv --passiv                e-ftp --no-check-certificate -P /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/downloads                 'http://petalinux.xilinx.com/sswreleases/rel-v2018.3/downloads/git2_github.com.01org.tbb.tar.gz' (for url http://pe                talinux.xilinx.com/sswreleases/rel-v2018.3/downloads/git2_github.com.01org.tbb.tar.gz)
ERROR: tbb-20170412+AUTOINC+a2cfdfe946-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/tmp/w                ork/aarch64-xilinx-linux/tbb/20170412+AUTOINC+a2cfdfe946-r0/temp/log.do_fetch.26928
ERROR: Task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembedded/meta-o                e/recipes-support/tbb/tbb.bb:do_fetch) failed with exit code '1'
ERROR: Task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembedded/meta-o                e/recipes-multimedia/v4l2apps/v4l-utils_1.12.3.bb:do_fetch) failed with exit code '1'
ERROR: opencv-3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0 do_fetch: Network access dis                abled through BB_NO_NETWORK (or set indirectly due to use of BB_FETCH_PREMIRRORONLY) but access requested with comm                and /usr/bin/env wget -t 2 -T 30 -nv --passive-ftp --no-check-certificate -P /home/ai/jiangkai/zcu102/petalinux2018                _prj/prj_mtcnn_mobilefacenet/build/downloads 'http://petalinux.xilinx.com/sswreleases/rel-v2018.3/downloads/git2_gi                thub.com.opencv.opencv.git.tar.gz' (for url http://petalinux.xilinx.com/sswreleases/rel-v2018.3/downloads/git2_gith                ub.com.opencv.opencv.git.tar.gz)
ERROR: opencv-3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0 do_fetch: Function failed: b                ase_do_fetch
ERROR: Logfile of failure stored in: /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/tmp/w                ork/aarch64-xilinx-linux/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0/temp/log.d                o_fetch.26931
ERROR: Task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/meta-openembedded/meta-o                e/recipes-support/opencv/opencv_3.3.bb:do_fetch) failed with exit code '1'
ERROR: gstreamer1.0-plugins-base-1.12.2+gitAUTOINC+71745a77db-r0 do_fetch: Network access disabled through BB_NO_NE                TWORK (or set indirectly due to use of BB_FETCH_PREMIRRORONLY) but access requested with command /usr/bin/env wget                 -t 2 -T 30 -nv --passive-ftp --no-check-certificate -P /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilef                acenet/build/downloads 'http://petalinux.xilinx.com/sswreleases/rel-v2018.3/downloads/git2_github.com.xilinx.gst-pl                ugins-base.git.tar.gz' (for url http://petalinux.xilinx.com/sswreleases/rel-v2018.3/downloads/git2_github.com.xilin                x.gst-plugins-base.git.tar.gz)
ERROR: gstreamer1.0-plugins-base-1.12.2+gitAUTOINC+71745a77db-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/ai/jiangkai/zcu102/petalinux2018_prj/prj_mtcnn_mobilefacenet/build/tmp/w                ork/aarch64-xilinx-linux/gstreamer1.0-plugins-base/1.12.2+gitAUTOINC+71745a77db-r0/temp/log.do_fetch.26929
ERROR: Task (/home/ai/jiangkai/zcu102/petalinux2018/components/yocto/source/aarch64/layers/core/meta/recipes-multim                edia/gstreamer/gstreamer1.0-plugins-base_1.12.2.bb:do_fetch) failed with exit code '1'
