mfltch
PetaLinux 2021.1 - unexpected MD5 for arm sstate-cache
Hi there,
Across 3 attempts, I've consistently calculated a different MD5 for the hosted PetaLinux 2021.1 arm sstate-cache.
Could Xilinx verify the hosted file & MD5 please?
Main page: https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
Direct file: https://www.xilinx.com/member/forms/download/xef.html?filename=sstate_arm_2021.1.tar.gz
Xilinx advertised MD5: fa24497730c88a8792a1581d295cbf5e
Locally calculated MD5: 4cf966dded3c7d581f83e4f474be7857
Many thanks, MF
sandeepg
Hi @mfltch ,
Yes you are right md5sum is not correct. We are working on this one and get fixed asap.
Sandeep
sandeepg
Hi @mfltch ,
Sandeep
mfltch
Thank you @sandeepg ,
I can see the MD5 has been updated on the product page.
I've re-downloaded the file & can confirm it matches the newly advertised MD5 (matching my original locally calculated MD5).
Many thanks for your help, Mark
sandeepg
Sounds good @mfltch !
Before
After
Sandeep
