PetaLinux BSP build error on TRD 2017.4
Dear Xilinx:
  I encounter build error when following the steps to build TRD2017.4
http://www.wiki.xilinx.com/Zynq%20UltraScale%20MPSoC%20Base%20TRD%202017.4%20-%20Design%20Module%201
here is my build error , would you guide me for the next step.
File: apu/petalinux_bsp/components/plnx_workspace/fsbl/.metadata/.log
!ENTRY org.eclipse.osgi 4 0 2018-03-20 16:09:10.224
!MESSAGE Application error
!STACK 1
java.lang.IllegalArgumentException: Argument cannot be null
at org.eclipse.swt.SWT.error(SWT.java:4514)
at org.eclipse.swt.SWT.error(SWT.java:4448)
at org.eclipse.swt.SWT.error(SWT.java:4419)
at org.eclipse.swt.graphics.Resource.<init>(Resource.java:50)
at org.eclipse.swt.graphics.Color.<init>(Color.java:80)
at com.xilinx.sdk.loggers.SdkLogAppender.initializeOutputStreams(SdkLogAppender.java:52)
at com.xilinx.sdk.loggers.SdkLogAppender.append(SdkLogAppender.java:83)
at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:251)
at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders(AppenderAttachableImpl.java:66)
at org.apache.log4j.Category.callAppenders(Category.java:206)
at org.apache.log4j.Category.forcedLog(Category.java:391)
at org.apache.log4j.Category.log(Category.java:856)
at org.slf4j.impl.Log4jLoggerAdapter.info(Log4jLoggerAdapter.java:304)
at com.xilinx.sdk.cmdline.application.SdkServiceStartUp.registerTcfCmdServers(SdkServiceStartUp.java:21)
at com.xilinx.sdk.cmdline.application.Service.start(Service.java:47)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
thanks for your work
Lucas
Dear XInlinx:
% cd project-spec/meta-user/recipes-bsp/device-tree/files/
% cp zcu102-base-dm1.dtsi system-user.dtsi
% petalinux-build
% cd -
I found that, if I do petalinux-build under the following path, it will caused the build error.
but if I do petalinux-build under the following path, the build error is bypassed.
$TRD_HOME/apu/petalinux_bsp
Thanks a lot.
BRs
CJ
Hi @a70024,
In http://www.wiki.xilinx.com/Zynq%20UltraScale%20MPSoC%20Base%20TRD%202017.4%20-%20Design%20Module%201 which command cause this build error.
Sandeep
Dear XInlinx:
% petalinux-build
% cd -
Thanks a lot.
BRs
CJ
