PetaLinux - Connection failed using port 32000 both with PC as server or ZedBoard as server
I'm using a Ubuntu 18 system on my PC and a PetaLinux on my ZedBoard. I'm trying to stabilish an ethernet connection via socket using a C++ code to connect them both, but strangely It ain't working.
I readed some tutorials and documentations and as suggested i'm using the port 32000 to avoid firewall problems.
Using the command "ifconfig eth0 192.168.0.10 up" I gave my ZedBoard an IP. For my ubunto ethernet connection I gave the address 192.168.0.200. I can ping between the ZedBoard and my Ubuntu.
I've written two C++ codes, one for my server and another for my client. My idea is that my PC is the server and my ZedBoard is the client. Here is it's codes.
server.cpp
// Server side C/C++ program to demonstrate Socket programming
#include <unistd.h>
#include <stdio.h>
#include <sys/socket.h>
#include <stdlib.h>
#include <netinet/in.h>
#include <string.h>
#define PORT 32000
int main(int argc, char const *argv[])
	int server_fd, new_socket, valread;
	struct sockaddr_in address;
	int opt = 1;
	int addrlen = sizeof(address);
	char buffer[1024] = {0};
	char *hello = "Hello from server";
	// Creating socket file descriptor
	if ((server_fd = socket(AF_INET, SOCK_STREAM, 0)) == 0)
		perror("socket failed");
		exit(EXIT_FAILURE);
	// Forcefully attaching socket to the port 8080
	if (setsockopt(server_fd, SOL_SOCKET, SO_REUSEADDR | SO_REUSEPORT,
												&opt, sizeof(opt)))
		perror("setsockopt");
		exit(EXIT_FAILURE);
	address.sin_family = AF_INET;
	address.sin_addr.s_addr = INADDR_ANY;
	address.sin_port = htons( PORT );
	if (bind(server_fd, (struct sockaddr *)&address,
								sizeof(address))<0)
		perror("bind failed");
		exit(EXIT_FAILURE);
	if (listen(server_fd, 3) < 0)
		perror("listen");
		exit(EXIT_FAILURE);
	if ((new_socket = accept(server_fd, (struct sockaddr *)&address,
					(socklen_t*)&addrlen))<0)
		perror("accept");
		exit(EXIT_FAILURE);
	valread = read( new_socket , buffer, 1024);
	printf("%s\n",buffer );
	send(new_socket , hello , strlen(hello) , 0 );
	printf("Hello message sent\n");
	return 0;
client.cpp
// Client side C/C++ program to demonstrate Socket programming
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <arpa/inet.h>
#include <unistd.h>
#define PORT 32000
	int sock = 0, valread;
	struct sockaddr_in serv_addr;
	char *hello = "Hello from client";
	if ((sock = socket(AF_INET, SOCK_STREAM, 0)) < 0)
		printf("\n Socket creation error \n");
		return -1;
	memset(&serv_addr, '0', sizeof(serv_addr));
	serv_addr.sin_family = AF_INET;
	serv_addr.sin_port = htons(PORT);
	serv_addr.sin_addr.s_addr = inet_addr("192.168.0.200");
	// Convert IPv4 and IPv6 addresses from text to binary form
	if(inet_pton(AF_INET, "127.0.0.1", &serv_addr.sin_addr)<=0)
		printf("\nInvalid address/ Address not supported \n");
		return -1;
	if (connect(sock, (struct sockaddr *)&serv_addr, sizeof(serv_addr)) < 0)
		printf("\nConnection Failed \n");
		return -1;
	send(sock , hello , strlen(hello) , 0 );
	valread = read( sock , buffer, 1024);
	return 0;
From my researches, I believed theses codes would work, but unfortunatelly i'm unable to stabilish a connecting using them. When I run the server on my PC and the client on the ZedBoard's PetaLinux it gives me Connectiong Failed.
Where is my mistake?
