PetaLinux System Image build error
Hi all,
I'm trying to build a Petalinux system image to hopefully get my custom board booting linux with sd card.
I have Vivado 2017.2 and Petalinux 2017.4, is that OK?
I'm following the UG1144 and I've managed to do all the steps up to page 21 but when I run petalinux-build I get the following errors on the terminal:
And this is what is in the log file mentioned on the terminal (log.do_configure.27420):
DEBUG: Executing python function sysroot_cleansstate
DEBUG: Python function sysroot_cleansstate finished
DEBUG: Executing shell function do_configure
MISC_ARG is  -yamlconf /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/device-tree-generation.yaml
APP_ARG is  -app "device-tree"
cmd is: xsct /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/dtgen.tcl -ws /opt/pkg/petalinux-v2017.4/sdproj/build/../components/plnx_workspace/device-tree -pname device-tree-generation -rp /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/git -processor ps7_cortexa9_0 -hdf /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/deploy/images/plnx_arm/Xilinx-plnx_arm.hdf -arch 32  -app "device-tree"  -yamlconf /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/device-tree-generation.yaml
INFO: [Hsi 55-1698] elapsed time for repository loading 9 seconds
hsi::open_hw_design: Time (s): cpu = 00:00:02 ; elapsed = 00:00:14 . Memory (MB): peak = 358.441 ; gain = 79.199 ; free physical = 193 ; free virtual = 6074
WARNING: ps7_i2c_0: No reset found
WARNING: ps7_usb_0: No reset found
Trying to assign a console::none which doesn't exists !!!
ERROR: [Hsi 55-1545] Problem running tcl command ::sw_device_tree::post_generate : Trying to assign a console::none which doesn't exists !!!
    while executing
"error "Trying to assign a console::$console_ip which doesn't exists !!!""
    (procedure "update_alias" line 27)
    invoked from within
"update_alias $os_handle"
    (procedure "::sw_device_tree::post_generate" line 3)
    invoked from within
"::sw_device_tree::post_generate device_tree"
ERROR: [Hsi 55-1443] Error(s) while running TCL procedure post_generate()
generate_target failed
    while executing
"error "generate_target failed""
    invoked from within
"if {[catch {hsi generate_target -dir $project} res]} {
    (file "/opt/pkg/petalinux-v2017.4/sdproj/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/dtgen.tcl" line 33)
WARNING: /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/run.do_configure.27420:1 exit 1 from 'eval xsct /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/dtgen.tcl -ws /opt/pkg/petalinux-v2017.4/sdproj/build/../components/plnx_workspace/device-tree -pname device-tree-generation -rp /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/git -processor ps7_cortexa9_0 -hdf /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/deploy/images/plnx_arm/Xilinx-plnx_arm.hdf -arch 32 ${APP_ARG} ${MISC_ARG}'
ERROR: Function failed: do_configure (log file is located at /opt/pkg/petalinux-v2017.4/sdproj/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/log.do_configure.27420)
Does anyone know why the building is failing? As mentioned before, it's a custom pcb and the SoC is a XC7Z020-1CLG400C.
Thank you in advance!
Re: PetaLinux System Image build error
Hi @alex83uk,
Looks like UART is missing in your design. Refer UG1144 page 17 and 18.
Sandeep
Hi @alex83uk,
Sandeep
Thank you Sandeep. I've added UART and it's now working.
Hallo,
I have same issue --------error "generate_target failed"
But after I tried to enable UART in my design, this issue appears again. What should I do now? Thanks
Holzmann
Hello Holzmann,
I'm sorry but I don't know. Adding the UART solved my problem.
Good luck.
Hallo,
thanks for reply, I solved it
can I know how did you solve this issue ?
Mohamed Taher
