dave74321
PetaLinux – When to use a Xilinx BSP?
I am creating a PetaLinux Project for a custom board that contains a Xilinx Zynq UltraScale+
(Vivado is running on Windows 10, and PetaLinux tools are running on a virtual machine with Ubuntu).
For a custom board should the PetaLinux project always be created from scratch?
petalinux-create --type project --template zynqMP --name <project name>
Or, if possible, are there advantages to using a Xilinx BSP from one of the Xilinx development boards (that is a nearest match to the custom board)?
petalinux-create -t project -s <path to bsp>.bsp
If using a Xilinx BSP:  As well as moving the Vivado exported HDF into the PetaLinux project folder and running petalinux-config, what else would need to be adjusted so that the project is able to target the custom board?
petalinux-config --get-hw-description
Thank you
stephenm
The BSP would be for the development board. If you use this BSP on your cusotm board then it will add all the external device nodes on the i2c bus. It will also add the symbol info to the fsbl to do some board level config, both would not be applicable to you
You are best to just use the
  • petalinux-create -t project --template zynqMP -n linux_proj
  • cd linux_proj
  • petalinux-config --get-hw-description=<path to hdf>
There is no real advantages over using the BSP for custom boards.
stephenm
  • cd linux_proj
