davethetroll
PetaLinux app missing from Kernel (2016.2)
I am attempting to build a simple kernel with a simple app.  From there I will make my changes to what I actually want.
I have followed the process, but when I boot linux my app does not appear in the bin directory.
. /opt/pkg/petalinux-v2016.2-final/settings.sh
petalinux-create --type project --template zynq --name rubux7 --source mz_7020_2016_2.bsp
cd rubux7
petalinux-config --get-hw-description ../project_1/project_1.sdk
petalinux-create --type apps --template c++ --name app_1
petalinux-config -c rootfs
	Apps ---> [*] app_1
***EDIT Makefile [original file references system_wrapper.bit which does not exist in my case]
	BOOT_BIT_IMAGE = subsystems/linux/hw-description/design_1_wrapper.bit
make
petalinux-boot --jtag --prebuilt 2
All seems to work, without any error messages.
When I log into PetaLinux, and "ls /bin" app_1 does not exist.
I initially had problems with this.  I had it working once.  But now I cannot replicate it.  I do not know what I did differently on the time that it worked.
I am no doubt missing some obvious and essential stage.  Can you help?
davethetroll
Finally found what I need.
petalinux-boot --jtag --kernel
to boot into the developed kernel
petalinux-boot --jtag --kernel --bitstream ../project_1/project_1.runs/impl_1/design_1_wrapper.bit
to also load the FPGA.
Copy boot.bin and image.ub from .../rubux7/images/linux folder into the SD card to boot from there.
sandeepg
Hi @davethetroll,
The problem is you are using prebuilt images not the one you have built.
Sandeep
davethetroll
I get the same when I boot using --u-boot instead of --prebuilt or copy the files to SD.
What is the solution?
How do I use the one I have built?
davethetroll
