PetaLinux build error after import hdf file from vivado
Hi all,
If I just create a project and build it, it could build correctly.
However, if I create a project, and import the hdf file, it runs into errors of fsbl compile failed.
I run command like this:
(1)petalinux-create -t project -n sProj -s avnet-digilent-zedboard-v2018.2-final.bsp
(2)cd sProj
(3)petalinux-config --get-hw-description=/home/hengzhao/vivado/iris_1/iris_1.sdk
(4)petalinux-build
Any idea what is wrong? Thanks a lot.
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Loading cache: 100% |###########################################################################################################| Time: 0:00:00
Loaded 3424 entries from dependency cache.
Parsing recipes: 100% |#########################################################################################################| Time: 0:00:03
Parsing of 2552 .bb files complete (2514 cached, 38 parsed). 3425 targets, 148 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |######################################################################################################| Time: 0:00:06
Checking sstate mirror object availability: 100% |##############################################################################| Time: 0:00:09
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: fsbl: compiling from external source tree /opt/pkg/petalinux/tools/hsm/data/embeddedsw
ERROR: fsbl-2018.2+gitAUTOINC+6e82c0183b-r0 do_compile: fsbl compile failed.
ERROR: fsbl-2018.2+gitAUTOINC+6e82c0183b-r0 do_compile: Function failed: do_compile (log file is located at /home/hengzhao/petalinux_project/secondProj/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/temp/log.do_compile.30867)
ERROR: Logfile of failure stored in: /home/hengzhao/petalinux_project/secondProj/build/tmp/work/zedboard_zynq7-xilinx-linux-gnueabi/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/temp/log.do_compile.30867
HI
Try below commands, I hope it should solve. if this not solve, share your HDF.
petalinux-build -x mrproper
petalinux-config--get-hw-description=<PATH-TO-HDF-DIRECTORY>
 petalinux-build
Thanks & regards
Aravind
Could be issue with your HDF, share your HDF.
Best Regards
Shabbir
Also, can you review the log file mention in the error message?
Whenever I got some cryptic fsbl build error, going though the whole vivado build chain helped (including recreating wrapper) and reexport the hdf.
Solved errors like this several times for me
HI
 petalinux-build
Thanks & regards
Aravind
Hi all, thanks for the reply.
It works when I run command like this:
(1)petalinux-create -t project --template zynq -n sProj
(2)cd sProj
(4)petalinux-build
