PetaLinux build error
Using petalinux version 2017.3 same with Vivado/SDK and Zedboard bsb on Ubuntu 16.04
Distributor ID: Ubuntu
Description: Ubuntu 16.04.6 LTS
Release: 16.04
Codename: xenial
Note on the same Ubuntu machine I have created about 25 Petalinux projects in the  past 2 years.
Here are the commands that I follow and issues i'm having.
petalinux-create -t project --name mmd_simp_1 --source /opt/zed_bsp/avnet-digilent-zedboard-v2017.3-final.bsp --force
PASSES
petalinux-config --get-hw-description simple_proj_1/simple_proj_1.sdk --project mmd_simp_1
PASSES
cd mmd_simp_1
PASSES
petalinux-config -c kernel
PASSES if I only have one console open, but gives errrors and fails when I have anther app opened.
petalinux-build
FAILS:
Here is a sample of the 44 errors (I have also attached the buld.log file:
NOTE: Executing SetScene Tasks
ERROR: external-hdf-1.0-r0 do_package_write_rpm_setscene: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
     0001:
 *** 0002:do_package_write_rpm_setscene(d)
     0003:
File: '/opt/pkg/petalinux/components/yocto/source/arm/layers/core/meta/classes/package_rpm.bbclass', lineno: 757, function: do_package_write_rpm_setscene
     0753:# but we need to stop the rootfs/solver from running while we do...
     0754:do_package_write_rpm[sstate-lockfile-shared] += "${DEPLOY_DIR_RPM}/rpm.lock"
     0755:
     0756:python do_package_write_rpm_setscene () {
 *** 0757:    sstate_setscene(d)
     0758:}
     0759:addtask do_package_write_rpm_setscene
     0760:
     0761:python do_package_write_rpm () {
File: '/opt/pkg/petalinux/components/yocto/source/arm/layers/core/meta/classes/sstate.bbclass', lineno: 659, function: sstate_setscene
     0655:            break
     0656:
     0657:def sstate_setscene(d):
     0658:    shared_state = sstate_state_fromvars(d)
 *** 0659:    accelerate = sstate_installpkg(shared_state, d)
     0660:    if not accelerate:
     0661:        bb.fatal("No suitable staging package found")
     0662:
     0663:python sstate_task_prefunc () {
File: '/opt/pkg/petalinux/components/yocto/source/arm/layers/core/meta/classes/sstate.bbclass', lineno: 327, function: sstate_installpkg
     0323:        bb.build.exec_func(f, d, (sstateinst,))
     0324:
     0325:    for state in ss['dirs']:
     0326:        prepdir(state[1])
 *** 0327:        os.rename(sstateinst + state[0], state[1])
     0328:    sstate_install(ss, d)
     0329:
     0330:    for plain in ss['plaindirs']:
     0331:        workdir = d.getVar('WORKDIR', True)
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/armen/mmd_simp_1/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/external-hdf/1.0-r0/sstate-install-package_write_rpm/deploy-rpms' -> '/home/armen/mmd_simp_1/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/external-hdf/1.0-r0/deploy-rpms'
WARNING: Logfile for failed setscene tasNOTE: Executing SetScene Tasks
     0001:
     0003:
     0755:
     0758:}
     0760:
     0655:            break
     0656:
     0662:
     0324:
     0329:
WARNING: Logfile for failed setscene task is /home/armen/mmd_simp_1/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/external-hdf/1.0-r0/temp/log.do_package_write_rpm_setscene.10980
ERROR: external-hdf-1.0-r0 do_populate_sysroot_setscene: Error executing a python function in exec_python_func() autogenerated:
     0001:
 *** 0002:do_populate_sysroot_setscene(d)
     0003:
File: '/opt/pkg/petalinux/components/yocto/source/arm/layers/core/meta/classes/staging.bbclass', lineno: 238, function: do_populate_sysroot_setscene
     0234:do_populate_sysroot[sstate-outputdirs] = "${STAGING_DIR_HOST}/"
     0235:do_populate_sysroot[stamp-extra-info] = "${MACHINE}"
     0236:
     0237:python do_populate_sysroot_setscene () {
 *** 0238:    sstate_setscene(d)
     0239:}
     0240:addtask do_populate_sysroot_setscene
     0241:
     0242:
     0655:            break
     0656:
     0662:
     0324:
     0329:
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/armen/mmd_simp_1/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/external-hdf/1.0-r0/sstate-install-populate_sysroot/sysroot-destdir' -> '/home/armen/mmd_simp_1/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/external-hdf/1.0-r0/sysroot-destdir'
WARNING: Logfile for failed setscene task is /home/armen/mmd_simp_1/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/external-hdf/1.0-r0/temp/log.do_populate_sysroot_setscene.10982
WARNING: Setscene task (/opt/pkg/petalinux/components/yocto/source/arm/layers/meta-xilinx-tools/recipes-bsp/hdf/external-hdf.bb:do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
WARNING: Setscene task (/opt/pkg/petalinux/components/yocto/source/arm/layers/meta-xilinx-tools/recipes-bsp/hdf/external-hdf.bb:do_populate_sysroot_setscene) failed with exit code '1' - real task will be run instead
     0001:
     0003:
     0236:
     0239:}
     0241:
     0242:
     0655:            break
     0656:
     0662:
     0324:
     0329:
