foss_enth
PetaLinux build fail
Hello FPGA community,
I am a new learner so please bear with me if the question is too vague. I will add details as required. I am trying to build my first PetaLinux for a custom board based on Zynq7010. I get a build error message. I tried twice from sctratch, i.e. a new design in Vivado, new Ubuntu virtual machine, installed PetaLinu, created a new project but got the same build error.
Here are a few details about my setup:
- Installed Vivado 2020.2 on Windows 10 laptop.
- Installed PetaLinux 2020.2 on virtual machine running Ubuntu 18.04.3.
And here is the error message:
ERROR: Task (~/petalinux2020.2/ebaz4205_NoY3/components/yocto/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/u-boot/u-boot-xlnx_2020.2.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3334 tasks of which 2606 didn't need to be rerun and 1 failed.
Let me know if you need further information.
Thank you for your support.
rambati
HI @foss_enth
May i know the which procedure your following ,Are you building with bsp or Are you building with template flow.
If you're building in template flow please share you xsa design , I can try at my end will see what is the issue.
Before that please make sure that your building petalinux in non root user and out of NFS location, You should install petalinux in local disk only.
Please cross-check petalinux build steps also once for template flow
1. petalinux-create --type project --template zynq --name cus_project
2. cd cus_project
3. petalinux-config --get-hw-description=<PATH TO HDF>
4. petalinux-build
Bsp flow
petalinux-create --type project -s <PATH TO BSP>
cd <plnx proj>
petalinux-config
petalinux-build
If all above are correct please error log and hdf file
Thanks and Regards
Raviteja
Don't Forget to Reply, Give Kudos, Accepted as Solution
foss_enth
Hi @rambati
Thank you for your reply. I am following the correct steps for template flow as shown above.
I have attached my *.xsa file. I attached also the latest console log and bitbake log files. If these files do not include the log you requested then please tell me where to find it or give me a file name to search for.
Thanks for looking into this.
NB: please note that when I posted this reply, the *.xsa file was removed and this error message was displayed in red:
"The attachment's designzynq7010_ps_wrapper.xsa content type (application/octet-stream) does not match its file extension and has been removed."
I have therefore, zipped the *.xsa file then attached it.
rambati
Hi @foss_enth
I am able to build at my end with your .xsa file
see log message here,
NOTE: Setscene tasks completed
NOTE: Tasks Summary: Attempted 3513 tasks of which 2615 didn't need to be rerun and all succeeded.
INFO: Failed to copy built images to tftp dir: /tftpboot
[INFO] Successfully built project
i wanted to know did you configured anything in petalinux-config, If not it should work
I would request you to do
petalinux-build -x mrproper
then petalinux-build
If still does not work please try to create new project and try again
Thanks and Regards
Raviteja
Don't forget to Reply, Give Kudos and Accepted as Solution
FOSS_entho
Hi @rambati
Yes, I made a few changes in petalinux-config. Most notably, I changed the default u-boot partition to "primary sd", and the netboot offset to 0x08000000. These changes did work for someone using PetaLinux2019. See: https://webuiltawallwebuiltthepyramids.blogspot.com/2021/01/ebaz4205-petalinux-installation.html What files do you need to be able to exactly reproduce my PetaLinux configuration?
NB: I had to create a new account to be able to reply as I could not reply using @foss_enth
rambati
Hi @FOSS_entho
We don't need to change default u-boot partition, It is already in "primary sd" and how did you changed netboot offset
can you provide steps you have modified
I would request you to build without any modifications and then check it is working as you expected or not.
Thanks and Regards
Raviteja
Don't Forget to Reply, Give Kudos and Accepted as Solution
foss_enth
Hi @rambati
I have tried again with minimum configuration changes as follows:
Auto Config Settings --> Check: * kernel autoconfig and *u-boot autoconfig
u-boot Configuration --> Change netboot offset to 0x08000000.
I still get a build error. I'll try again without any changes and report back...
foss_enth
Hi @rambati
I can confirm that the build is successful with the default configuration.
I packaged the necessary fiiles then copied them to an SD card (FAT32 formatted). Unfortunately, the board does not boot.
It looks like the build fails as soon as I select kernel and u-boot autoconfig. If I do not, then I will not be able to change the netboot offset.
rambati
HI @foss_enth
Why it is not booting could please share log file and what are the you're copying into sd card.
You should copy image.ub and BOOT.BIN into sd card
Thanks and Regards
Raviteja
foss_enth
Hi @rambati
I am pleased to say there has been some progress over the weekend.
There are two reasons which cause boot failure;
1- Copying BOOT.BIN and image.ub to the SD card is not enough. The image.scr file also must be included. This is one of the differences between PetaLinux 2019 and 2020 versions.
2- By default, image.scr script tries to load image.ub to RAM at 0x10000000 which is 256MiB. This is fine for boards incorporating larger amounts of RAM, however my custom board features a single 256MiB RAM chip, and therefore it is impossible to load image.ub at this address.
To change the default RAM loading address one must choose in hardware configuration step "u-boot autoconfig" then change the address, for example to 0x08000000 as indicated above. Unfortunately, this causes the build process to fail. Why? I think this is a question for you @rambati: Why does build fail when the option "u-boot autoconfig" is selected?
I found a workaround to boot anyway after inspecting the boot.scr file. When booting from SD card the script attempts first to load image.ub. If it does not find it, it will then attemp to load the three files used to make image.ub individually, i.e. rootfs.cpio.gz.u-boot AND uImage AND system.dtb.
rambati
HI @foss_enth
Please go through this AR for u-boot modifications https://www.xilinx.com/support/answers/75730.html
Hope it should helpful
Thanks and Regards
Raviteja
foss_enth
Thanks @rambati . I do not think that AR# 75730 is talking about the same issue.
I have a few more questions I would appreciate if you could help me with. I am going to post them one at a time:
1- When trying to boot from SD card including BOOT.BIN AND image.ub only, then it does not boot and kernel fails to load but network (ethernet) seems to work, as the board gets assigned a valid IP address from my router. However, when I include image.scr file although the board boots to linux successfully, the network does not work: udhcpc starts then sends three times discover then does not manage to get a lease and forks to background! whatever this means see exerpt below:
Configuring network interfaces... macb e000b000.ethernet eth0: unable to generate target frequency: 25000000 Hz
macb e000b000.ethernet eth0: link up (100/Full)
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
udhcpc: started, v1.31.0
udhcpc: sending discover
udhcpc: no lease, forking to background
done.
I have included the full UART log and output of ifconfig and cat /etc/network/interfaces
root@zynq7010:~# ifconfig
eth0 Link encap:Ethernet HWaddr 00:0A:35:00:1E:53
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:25 Base address:0xb000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
