bluetiger9
PetaLinux build fails with locale errors. How to disable locale checks?
I'm unable to build PetaLinux, because of some (probably harmless) locale errors in the petalinux-user-image log:
bluetiger@Attila-Laptop:xilinx-ultra96-reva-2018.2$ source /media/bluetiger/Data/Xilinx/PetaLinux/settings.sh
PetaLinux environment set to '/media/bluetiger/Data/Xilinx/PetaLinux'
WARNING: /bin/sh is not bash!
bash is PetaLinux recommended shell. Please set your default shell to bash.
INFO: Checking free disk space
INFO: Checking installed tools
environment: line 281: ((: 10#15~1 > 10#3: syntax error in expression (error token is "~1 > 10#3")
environment: line 285: ((: 10#15~1 < 10#3: syntax error in expression (error token is "~1 < 10#3")
INFO: Checking installed development libraries
INFO: Checking network and other services
WARNING: No tftp server found - please refer to "PetaLinux SDK Installation Guide" for its impact and solution
bluetiger@Attila-Laptop:xilinx-ultra96-reva-2018.2$ echo $PETALINUX
bluetiger@Attila-Laptop:xilinx-ultra96-reva-2018.2$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
WARNING: Host distribution "ubuntu-18.04" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |##################################################################################################################| Time: 0:00:00
Loaded 3437 entries from dependency cache.
Parsing recipes: 100% |################################################################################################################| Time: 0:00:05
Parsing of 2552 .bb files complete (2513 cached, 39 parsed). 3441 targets, 135 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#############################################################################################################| Time: 0:00:40
Checking sstate mirror object availability: 100% |#####################################################################################| Time: 0:00:22
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
WARNING: petalinux-user-image-1.0-r0 do_rootfs: [log_check] petalinux-user-image: found 1 warning message in the logfile:
[log_check] warning: %post(sysvinit-inittab-2.88dsf-r10.ultra96_zynqmp) scriptlet failed, exit status 1
ERROR: petalinux-user-image-1.0-r0 do_rootfs: [log_check] petalinux-user-image: found 4 error messages in the logfile:
[log_check] Failed to set locale, defaulting to C
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /media/bluetiger/Data/PetaLinux-Ultra96/xilinx-ultra96-reva-2018.2/build/tmp/work/ultra96_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp/log.do_rootfs.5592
ERROR: Task (/media/bluetiger/Data/PetaLinux-Ultra96/xilinx-ultra96-reva-2018.2/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb:do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 10052 tasks of which 10051 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
The locales seems to be just fine:
bluetiger@Attila-Laptop:~$ locale
LANG=en_US.UTF-8
LANGUAGE=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=en_US.UTF-8
I tried all the possible solutions I found on the net, but nothing help.
Yesterday, I had a similar problem with bitbake's sanity checks, but I solved this by commenting out some code in sanity_check_locale() from sanity.bbclass.
Does anyone know what causes the problem?
Does anyone know how to fix / bypass this problem?
Can I edit the source of petalinux-user-image do disable the check?
Can I disable log_check for petalinux-user-image?
I would really appreciate any help on this. This error starts getting really frustrating...
Note: I'm experiencing this on Ubuntu 18.04 LTS.
Attila
bluetiger9
I found a (pretty ugly) workaround for the problem today...
The problem is caused by an incompatibility between Ubuntu 18.04 LTS (probably some updated library) and the Python 3.5 included in Yocto / PetaLinux.
The workaround is to edit the ".../usr/lib/python3.5/locale.py" file(s) and make the setlocale() function fail quietly:
def setlocale(category, locale=None):
    """ Set the locale for the given category.  The locale can be
        a string, an iterable of two strings (language code and encoding),
        or None.
        Iterables are converted to strings using the locale aliasing
        engine.  Locale strings are passed directly to the C lib.
        category may be given as one of the LC_* values.
    if locale and not isinstance(locale, _builtin_str):
        # convert to string
        locale = normalize(_build_localename(locale))
    try:
        return _setlocale(category, locale)
    except:
        pass
The files appears in multiple locations. I edited all of them, but probably no all are needed:
  • PetaLinux install directory:
    ./components/yocto/source/buildtools/sysroots/x86_64-petalinux-linux/usr/lib/python3.5/locale.py
    ./components/yocto/source/aarch64/buildtools/sysroots/x86_64-petalinux-linux/usr/lib/python3.5/locale.py
  • build directory
    ./build/tmp/sysroots-components/x86_64/python3-native/usr/lib/python3.5/locale.py
    ./build/tmp/sysroots-components/aarch64/python3/usr/lib/python3.5/locale.py
    ./build/tmp/work/ultra96_zynqmp-xilinx-linux/pmu-firmware/2018.2+gitAUTOINC+6e82c0183b-r0/recipe-sysroot-native/usr/lib/python3.5/locale.py
    ./build/tmp/work/ultra96_zynqmp-xilinx-linux/linux-xlnx/4.14-xilinx-v2018.2+gitAUTOINC+ad4cd988ba-r0/recipe-sysroot-native/usr/lib/python3.5/locale.py
    ./build/tmp/work/ultra96_zynqmp-xilinx-linux/fsbl/2018.2+gitAUTOINC+6e82c0183b-r0/recipe-sysroot-native/usr/lib/python3.5/locale.py
    ./build/tmp/work/ultra96_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/recipe-sysroot-native/usr/lib/python3.5/locale.py
    ./build/tmp/work/ultra96_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/rootfs/usr/lib/python3.5/locale.py
Cheers,
Attila
sandeepg
Refer this AR https://www.xilinx.com/support/answers/71448.html
Sandeep
quypham
I have the same error. Did you find a  working solution yet?
The above link does not work. Please provide another.
bluetiger9
The linked AR (remove the %C2%A0 from the link) just states that Ubuntu 18.04.x LTS is not officially supported.
I didn't have a solution yet. I posted a message on the Yocto mailing list, so hope we get more details about what the problem is.
quypham
I didn't find a solution for the error but I have successfully build the image and generate BOOT.BIN with Ubuntu 16.04.1.
You should switch to this older version bluetiger9
bluetiger9
        or None.
        # convert to string
    try:
    except:
        pass
  • build directory
Cheers,
Attila
zc102test
Hi Attila,
I really appreciate you for the solution, after change those files, it does work on my Ubuntu18.10 64bit server release.
Thank you very much!!
Best Regards,
Jianhua Xie
petearris
I am getting the same error when building u-boot and I am using Ubuntu 16.04.
petalinux-build -c u-boot
[INFO] building u-boot
INFO: bitbake virtual/bootloader
ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
Please set a valid MACHINE in your local.conf or environment
eengie
Besides the sanity.bbclass change, the only other file I had to change was:
./build/tmp/sysroots-components/x86_64/dnf-native/usr/lib/python3.5/site-packages/dnf/i18n.py
The issue is the "print" statement in there that says, Failed to set locale, defaulting to C.  The log sanity checker sees "Failed" in plain text and assumes it was a failure.
In my case, I was generating a root file system (do_rootfs task).
