PetaLinux can't build when I add a socket C code that sets the IP Address but does compile when I don't set it
I'm trying to work with some communication projects and writed a C code for a server and another for a client. Initially, my server and client did not specify the IP address for the communication, leaving it as INADDR_ANY. I added both as apps for my PetaLinux and them both compiled and runned on my ZedBoard perfectly.
Now, I modified the client code to specify an IP address, but, even the code compiling normaly on my Ubuntu, it doesn't compiles when I run petalinux-build.
Here is my client.cpp
// Client side C/C++ program to demonstrate Socket programming
#include <stdio.h>
#include <sys/socket.h>
#include <stdlib.h>
#include <netinet/in.h>
#include <string.h>
#include <arpa/inet.h>
#include <unistd.h>
#define PORT 8080
int main(int argc, char const *argv[])
	struct sockaddr_in address;
	int sock = 0, valread;
	struct sockaddr_in serv_addr;
	char *hello = "Hello from client";
	char buffer[1024] = {0};
	if ((sock = socket(AF_INET, SOCK_STREAM, 0)) < 0)
		printf("\n Socket creation error \n");
		return -1;
	memset(&serv_addr, '0', sizeof(serv_addr));
	serv_addr.sin_family = AF_INET;
	serv_addr.sin_port = htons(PORT);
	serv_addr.sin_addr.s_addr = inet_addr("192.168.0.200");
	// Convert IPv4 and IPv6 addresses from text to binary form
	if(inet_pton(AF_INET, "127.0.0.1", &serv_addr.sin_addr)<=0)
		printf("\nInvalid address/ Address not supported \n");
		return -1;
	if (connect(sock, (struct sockaddr *)&serv_addr, sizeof(serv_addr)) < 0)
		printf("\nConnection Failed \n");
		return -1;
	send(sock , hello , strlen(hello) , 0 );
	printf("Hello message sent\n");
	valread = read( sock , buffer, 1024);
	printf("%s\n",buffer );
	return 0;
If I remove the line <serv_addr.sin_addr.s_addr = inet_addr("192.168.0.200");/> it compiles and runs normally.
The error I get is simillar to the following:Screenshot from 2019-03-17 11-32-11.png
I'm trying the figure out why it's happening. Can you helpe me?
Thanks in advance,
Tiago
Re: PetaLinux can't build when I add a socket C code that sets the IP Address but does compile when I don't set it
For the first issue:
"No rule to make target clean"
Can you update the makefile in
project-spec\meta-user\recipes-apps\<app name>
clean:
    -rm -f $(APP) *.elf *.gdb *.o $(APP_OBJS)
Also, if you are suing sockets you would need to add the pthreads to the make file
LDLIBS += -lpthread
clean:
LDLIBS += -lpthread
It worked! Thanks
