Voyager
Voyager
PetaLinux doesn't see libtool, so it won't run
Dear Xilinx community,
I am trying to setup the petalinux sdk on my debian system, but petalinux doesn't see libtool as installed so I am stuck because it won't run.
The error it fires is:
INFO: Checking installed tools
ERROR: You are missing the following system tools required by PetaLinux:
 - libtool
Please check PetaLinux installation guide - required tools and libraries pacakge section for detailed information
which is not true:
$ dpkg -l | grep libtool
ii libltdl-dev:amd64 2.4.2-1.11+b1 amd64 System independent dlopen wrapper for GNU libtool ii libltdl7:amd64 2.4.2-1.11+b1 amd64 System independent dlopen wrapper for GNU libtool rc libltdl7:i386 2.4.2-1.11+b1 i386 System independent dlopen wrapper for GNU libtool ii libtool 2.4.2-1.11 all Generic library support script
The petalinux-env-check is a binary file, so I cannot modify it as a shell script.
How can I instruct to petalinux where he can find the libtool package ?
Thank you in advance,
Simon
Re: PetaLinux doesn't see libtool, so it won't run
i had the same error on Linux Mint and installing libtool-bin removed it from the list in my case
Thank you for the tip and it is still valid in 2019 on Linux Mint 19.1.
