PetaLinux environment build_with_: command not found
Hi;
I am using PetaLinux 2019.2 and try to creat a Petalinux project.
create a petalinux project, configure the project, and then build the project by runnig "petalinux-build", but I receive the floowing error:
[INFO] building project
[INFO] sourcing bitbake
[INFO] generating user layers
[INFO] generating workspace directory
environment: line 2504: build_with_: command not found
ERROR: Failed to build project
Could you please advise me how to resolve this issue?
I would greatly appreciate if someone answer my query.
Thank you.
Re: PetaLinux environment build_with_: command not found
@satguy well. I worked on this issue for a few days. I couldn't resolve it. Apart from this server, I got several servers in the lab and installed the software on one of them. Now I can see everything is fine and I don't receive this error anymore....
"create a petalinux project, configure the project, and then build the project"
Maybe all the evil is in that configuration you bundle it all behind a word. Could you attach the config file?
Bear in mind Petalinux wraps Yocto that is build in Python and whenever there is an error, there is a spew of lines of code (you haven't written), Python file errors (you don't know anything about) and possibly additional random characters, all in red, probably to try to provoke a stroke to the user to minimize the number of complains.
In ancient times, error messages had the purpose of guiding the user to sort them out. now the purpose seem to be to scroll some line to change the overall color.
@satguy Thanks for your message.
I have attached the file. ( I changed it to .txt as it can't be attched if I dont do it)
quite a standard config... I'm not sure about this:
CONFIG_SUBSYSTEM_HOSTNAME="zcu102_dpu-ubuntu-petalinux"
CONFIG_SUBSYSTEM_PRODUCT="zcu102_dpu-ubuntu-petalinux"
Are you building ubuntu for Zynq?
@satguy No , I am not at this stage, only the name is 'zcu102_dpu-ubuntu-petalinux'
Here are the commands I used:
hpnroot@hpn118:/opt/workspace/DPU$ petalinux-create -t project --template zynqMP -n zcu102_dpu-ubuntu-petalinux
INFO: Create project: zcu102_dpu-ubuntu-petalinux
INFO: New project successfully created in /opt/workspace/DPU/zcu102_dpu-ubuntu-petalinux
hpnroot@hpn118:/opt/workspace/DPU$ cd zcu102_dpu-ubuntu-petalinux/
hpnroot@hpn118:/opt/workspace/DPU/zcu102_dpu-ubuntu-petalinux$ petalinux-config --get-hw-description=../hardware_files
INFO: Getting hardware description...
INFO: Rename zcu102_dpu.xsa to system.xsa
[INFO] generating Kconfig for project
[INFO] menuconfig project
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
[INFO] generating bbappends for project . This may take time !
[INFO] generating u-boot configuration files
[INFO] generating kernel configuration files
[INFO] generating kconfig for Rootfs
[INFO] silentconfig rootfs
[INFO] generating petalinux-user-image.bb
hpnroot@hpn118:/opt/workspace/DPU/zcu102_dpu-ubuntu-petalinux$ petalinux-build
emm, I don't think you should be root (are you?) and developing in /opt
Could you try as normal user and in the user folder?
@satguy both root and normal user are the same :
-normal user :
configuration written to /opt/workspace/DPU/zcu102_dpu-ubuntu-petalinux/project-spec/configs/config_zcu102_dpu
-root:
root@hpn118:/opt/workspace/DPU# petalinux-create -t project --template zynqMP -n zcu102_dpu-ubuntu-petalinux
root@hpn118:/opt/workspace/DPU# cd zcu102_dpu-ubuntu-petalinux/
root@hpn118:/opt/workspace/DPU/zcu102_dpu-ubuntu-petalinux# petalinux-config --get-hw-description=../hardware_files
root@hpn118:/opt/workspace/DPU/zcu102_dpu-ubuntu-petalinux# petalinux-build
Check the warning about installing Petalinux tools with regards to user levels.
Have you been able to build any project with that tool? Can you try a basic build with a known BSP (whichever) for a known supported board (that would discard the problem is with the tool)
@satguy yes , I don't know why this one doesn't work
Well, if you have something that works and something that doesn't, I'd look into the differences. Another approach: take your project with a default config, build it, and change things until it fails. Slow, I know, as it takes a while every time.
Another thing: have you tried petalinux-build -x mrproper? Whenever you build, it reuses things, I've got into errors that vanished after that. Or at least, -x distclean
