PetaLinux hangs at login
Hello. I have a problem with my board zynq ultrascale.
PetaLinux hangs after login.
U-Boot 2019.01 (Dec 17 2019 - 23:15:22 +0000)
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
DRAM: 4 GiB
EL Level: EL2
Chip ID: zu3eg
MMC: mmc@ff160000: 0
Loading Environment from SPI Flash... SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
## Error: flags type check failure for "serverip" <= "AUTO" (type: i)
himport_r: can't insert "serverip=AUTO" into hash table
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Bootmode: QSPI_MODE
Reset reason: EXTERNAL
Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for zynq_poject
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
Abort
ZynqMP> setenv ipaddr 192.168.2.105
ZynqMP> setenv serverip 192.168.2.1
ZynqMP> run netboot
Using ethernet@ff0e0000 device
TFTP from server 192.168.2.1; our IP address is 192.168.2.105
Filename 'image.ub'.
Load address: 0x10000000
Loading: #################################################################
9.2 MiB/s
done
Bytes transferred = 24810736 (17a94f0 hex)
Using 'conf@system-top.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x100000f8
Data Size: 18082304 Bytes = 17.2 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00080000
Entry Point: 0x00080000
Hash algo: sha1
Hash value: 31c6e0fe54a854eba48d0cd9c834b5c6d429a75a
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: petalinux-user-image
Type: RAMDisk Image
Compression: gzip compressed
Data Start: 0x11149650
Data Size: 6682893 Bytes = 6.4 MiB
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 4cc83feb85bf1a20917c7c5d744310b9b4a015ad
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x1113ebfc
Data Size: 43407 Bytes = 42.4 KiB
Hash algo: sha1
Hash value: b8fa0cfa7d3271c89b8bfc944526ec309d095fc8
Booting using the fdt blob at 0x1113ebfc
Loading Kernel Image ... OK
Loading Ramdisk to 789a0000, end 78fff90d ... OK
Loading Device Tree to 0000000007ff2000, end 0000000007fff98e ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.0-xilinx-v2019.2 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP Mon Dec 9 18:55:27 UTC 2019
[ 0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 256 MiB at 0x0000000068800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
[ 0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s53016 r8192 d28904 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1033987
[ 0.000000] Kernel command line: earlycon console=ttyPS0,115200 clk_ignore_unused
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB: mapped [mem 0x7beff000-0x7feff000] (64MB)
[ 0.000000] Memory: 3776232K/4193280K available (10748K kernel code, 634K rwdata, 5420K rodata, 832K init, 314K bss, 154904K reserved, 262144K cma-reserved)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 50.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb8812736b, max_idle_ns: 440795202655 ns
[ 0.000003] sched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 4398046511100ns
[ 0.008229] Console: colour dummy device 80x25
[ 0.012390] Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=200000)
[ 0.022754] pid_max: default: 32768 minimum: 301
[ 0.027446] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.034008] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.041790] ASID allocator initialised with 32768 entries
[ 0.046506] rcu: Hierarchical SRCU implementation.
[ 0.051520] EFI services will not be available.
[ 0.055823] smp: Bringing up secondary CPUs ...
[ 0.060480] Detected VIPT I-cache on CPU1
[ 0.060508] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.060813] Detected VIPT I-cache on CPU2
[ 0.060832] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.061118] Detected VIPT I-cache on CPU3
[ 0.061136] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.061181] smp: Brought up 1 node, 4 CPUs
[ 0.095672] SMP: Total of 4 processors activated.
[ 0.100345] CPU features: detected: 32-bit EL0 Support
[ 0.106893] CPU: All CPU(s) started at EL2
[ 0.109523] alternatives: patching kernel code
[ 0.114784] devtmpfs: initialized
[ 0.121858] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.126911] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.138515] xor: measuring software checksum speed
[ 0.177112] 8regs : 2375.000 MB/sec
[ 0.217142] 8regs_prefetch: 2052.000 MB/sec
[ 0.257173] 32regs : 2725.000 MB/sec
[ 0.297202] 32regs_prefetch: 2308.000 MB/sec
[ 0.297242] xor: using function: 32regs (2725.000 MB/sec)
[ 0.301549] pinctrl core: initialized pinctrl subsystem
[ 0.307302] NET: Registered protocol family 16
[ 0.311383] audit: initializing netlink subsys (disabled)
[ 0.316605] audit: type=2000 audit(0.264:1): state=initialized audit_enabled=0 res=1
[ 0.324205] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.324209] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.338956] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.357589] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.424613] raid6: int64x1 gen() 446 MB/s
[ 0.492615] raid6: int64x1 xor() 450 MB/s
[ 0.560677] raid6: int64x2 gen() 680 MB/s
[ 0.628704] raid6: int64x2 xor() 599 MB/s
[ 0.696807] raid6: int64x4 gen() 981 MB/s
[ 0.764848] raid6: int64x4 xor() 731 MB/s
[ 0.832910] raid6: int64x8 gen() 1162 MB/s
[ 0.900967] raid6: int64x8 xor() 759 MB/s
[ 0.969042] raid6: neonx1 gen() 736 MB/s
[ 1.037097] raid6: neonx1 xor() 880 MB/s
[ 1.105175] raid6: neonx2 gen() 1129 MB/s
[ 1.173239] raid6: neonx2 xor() 1173 MB/s
[ 1.241325] raid6: neonx4 gen() 1479 MB/s
[ 1.309385] raid6: neonx4 xor() 1417 MB/s
[ 1.377462] raid6: neonx8 gen() 1536 MB/s
[ 1.445510] raid6: neonx8 xor() 1459 MB/s
[ 1.445547] raid6: using algorithm neonx8 gen() 1536 MB/s
[ 1.449496] raid6: .... xor() 1459 MB/s, rmw enabled
[ 1.454432] raid6: using neon recovery algorithm
[ 1.459752] SCSI subsystem initialized
[ 1.462897] usbcore: registered new interface driver usbfs
[ 1.468219] usbcore: registered new interface driver hub
[ 1.473491] usbcore: registered new device driver usb
[ 1.478541] media: Linux media interface: v0.10
[ 1.482999] videodev: Linux video capture interface: v2.00
[ 1.488450] pps_core: LinuxPPS API ver. 1 registered
[ 1.493358] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.502451] PTP clock support registered
[ 1.506349] EDAC MC: Ver: 3.0.0
[ 1.509827] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[ 1.516906] FPGA manager framework
[ 1.520229] Advanced Linux Sound Architecture Driver Initialized.
[ 1.526412] Bluetooth: Core ver 2.22
[ 1.529703] NET: Registered protocol family 31
[ 1.534101] Bluetooth: HCI device and connection manager initialized
[ 1.540416] Bluetooth: HCI socket layer initialized
[ 1.545259] Bluetooth: L2CAP socket layer initialized
[ 1.550290] Bluetooth: SCO socket layer initialized
[ 1.555412] clocksource: Switched to clocksource arch_sys_counter
[ 1.561251] VFS: Disk quotas dquot_6.6.0
[ 1.565159] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.576134] NET: Registered protocol family 2
[ 1.576551] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 1.584055] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 1.591390] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.598141] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.604313] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.610290] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.616765] NET: Registered protocol family 1
[ 1.621161] RPC: Registered named UNIX socket transport module.
[ 1.626834] RPC: Registered udp transport module.
[ 1.631500] RPC: Registered tcp transport module.
[ 1.636169] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.642910] Trying to unpack rootfs image as initramfs...
[ 1.922124] Freeing initrd memory: 6524K
[ 1.922490] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.927678] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.936104] Initialise system trusted keyrings
[ 1.939692] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 1.946722] NFS: Registering the id_resolver key type
[ 1.951051] Key type id_resolver registered
[ 1.955191] Key type id_legacy registered
[ 1.959174] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.965843] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 3.059419] NET: Registered protocol family 38
[ 3.117835] Key type asymmetric registered
[ 3.117873] Asymmetric key parser 'x509' registered
[ 3.121194] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 3.128496] io scheduler noop registered
[ 3.132386] io scheduler deadline registered
[ 3.136662] io scheduler cfq registered (default)
[ 3.141297] io scheduler mq-deadline registered
[ 3.145793] io scheduler kyber registered
[ 3.177388] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 3.181336] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 3.188205] brd: module loaded
[ 3.191939] loop: module loaded
[ 3.192768] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 3.197979] libphy: Fixed MDIO Bus: probed
[ 3.201998] tun: Universal TUN/TAP device driver, 1.6
[ 3.205901] CAN device driver interface
[ 3.210486] usbcore: registered new interface driver asix
[ 3.214991] usbcore: registered new interface driver ax88179_178a
[ 3.221029] usbcore: registered new interface driver cdc_ether
[ 3.226823] usbcore: registered new interface driver net1080
[ 3.232445] usbcore: registered new interface driver cdc_subset
[ 3.238328] usbcore: registered new interface driver zaurus
[ 3.243874] usbcore: registered new interface driver cdc_ncm
[ 3.249956] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.255953] ehci-pci: EHCI PCI platform driver
[ 3.260624] usbcore: registered new interface driver uas
[ 3.265671] usbcore: registered new interface driver usb-storage
[ 3.272113] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 3.278844] i2c /dev entries driver
[ 3.283853] usbcore: registered new interface driver uvcvideo
[ 3.287957] USB Video Class driver (1.1.1)
[ 3.292900] Bluetooth: HCI UART driver ver 2.3
[ 3.296439] Bluetooth: HCI UART protocol H4 registered
[ 3.301537] Bluetooth: HCI UART protocol BCSP registered
[ 3.306832] Bluetooth: HCI UART protocol LL registered
[ 3.311917] Bluetooth: HCI UART protocol ATH3K registered
[ 3.317295] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 3.323546] Bluetooth: HCI UART protocol Intel registered
[ 3.328887] Bluetooth: HCI UART protocol QCA registered
[ 3.334092] usbcore: registered new interface driver bcm203x
[ 3.339709] usbcore: registered new interface driver bpa10x
[ 3.345245] usbcore: registered new interface driver bfusb
[ 3.350695] usbcore: registered new interface driver btusb
[ 3.356119] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 3.361785] usbcore: registered new interface driver ath3k
[ 3.367313] EDAC MC: ECC not enabled
[ 3.370863] EDAC DEVICE0: Giving out device to module edac controller cache_err: DEV edac (POLLED)
[ 3.379821] EDAC DEVICE1: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 3.392211] sdhci: Secure Digital Host Controller Interface driver
[ 3.397898] sdhci: Copyright(c) Pierre Ossman
[ 3.402221] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.408177] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.413858] zynqmp_firmware_probe Platform Management API v1.1
[ 3.419613] zynqmp_firmware_probe Trustzone version v1.0
[ 3.427621] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[ 3.455298] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[ 3.458008] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[ 3.463117] zynqmp_aes zynqmp_aes: AES Successfully Registered
[ 3.463117]
[ 3.470635] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 3.476767] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 3.482403] usbcore: registered new interface driver usbhid
[ 3.487671] usbhid: USB HID core driver
[ 3.493705] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 3.498248] usbcore: registered new interface driver snd-usb-audio
[ 3.504893] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 3.511921] Initializing XFRM netlink socket
[ 3.515852] NET: Registered protocol family 10
[ 3.520542] Segment Routing with IPv6
[ 3.523910] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.530031] NET: Registered protocol family 17
[ 3.534127] NET: Registered protocol family 15
[ 3.538542] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this .
[ 3.551455] can: controller area network core (rev 20170425 abi 9)
[ 3.557665] NET: Registered protocol family 29
[ 3.561975] can: raw protocol (rev 20170425)
[ 3.566210] can: broadcast manager protocol (rev 20170425 t)
[ 3.571834] can: netlink gateway (rev 20170425) max_hops=1
[ 3.577351] Bluetooth: RFCOMM TTY layer initialized
[ 3.582135] Bluetooth: RFCOMM socket layer initialized
[ 3.587237] Bluetooth: RFCOMM ver 1.11
[ 3.590953] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.596225] Bluetooth: BNEP filters: protocol multicast
[ 3.601416] Bluetooth: BNEP socket layer initialized
[ 3.606346] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.612229] Bluetooth: HIDP socket layer initialized
[ 3.617271] 9pnet: Installing 9P2000 support
[ 3.621414] Key type dns_resolver registered
[ 3.626017] registered taskstats version 1
[ 3.629706] Loading compiled-in X.509 certificates
[ 3.634795] Btrfs loaded, crc32c=crc32c-generic
[ 3.645201] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 39, base_baud = 6250000) is a xuartps
[ 3.654442] console [ttyPS0] enabled
[ 3.658041] bootconsole [cdns0] disabled
[ 3.666108] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 40, base_baud = 6250000) is a xuartps
[ 3.679504] of-fpga-region fpga-full: FPGA Region probed
[ 3.685444] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 3.692541] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 3.699640] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 3.706743] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 3.713838] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 3.720946] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 3.728043] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 3.735143] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 3.742315] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[ 3.749411] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[ 3.756511] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[ 3.763613] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[ 3.770715] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[ 3.777813] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[ 3.784912] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[ 3.792018] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[ 3.799311] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[ 3.817249] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 3.826204] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 3.835941] zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13
[ 3.843988] scsi host0: ahci-ceva
[ 3.847554] scsi host1: ahci-ceva
[ 3.850995] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
[ 3.858908] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
[ 3.870425] m25p80 spi0.0: n25q512a (131072 Kbytes)
[ 3.875322] 3 fixed-partitions partitions found on MTD device spi0.0
[ 3.881671] Creating 3 MTD partitions on "spi0.0":
[ 3.886455] 0x000000000000-0x000000100000 : "boot"
[ 3.891745] 0x000000100000-0x000000140000 : "bootenv"
[ 3.897251] 0x000000140000-0x000001740000 : "kernel"
[ 3.903956] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 3.911351] libphy: MACB_mii_bus: probed
[ 3.919664] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POL L)
[ 3.932701] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 29 (00:0a:35:00:22:01)
[ 3.942882] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 3.949431] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 3.955914] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 3.962394] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 3.970238] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[ 3.976078] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[ 3.986270] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.991762] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 3.999713] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[ 4.009115] xhci-hcd xhci-hcd.0.auto: irq 42, io mem 0xfe200000
[ 4.015240] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 4.023501] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.030717] usb usb1: Product: xHCI Host Controller
[ 4.035585] usb usb1: Manufacturer: Linux 4.19.0-xilinx-v2019.2 xhci-hcd
[ 4.042276] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 4.047443] hub 1-0:1.0: USB hub found
[ 4.051196] hub 1-0:1.0: 1 port detected
[ 4.055302] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.060792] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 4.068447] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 4.075169] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 4.083433] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.090651] usb usb2: Product: xHCI Host Controller
[ 4.095519] usb usb2: Manufacturer: Linux 4.19.0-xilinx-v2019.2 xhci-hcd
[ 4.102211] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 4.107317] hub 2-0:1.0: USB hub found
[ 4.111078] hub 2-0:1.0: 1 port detected
[ 4.117903] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 1200000 KHz
[ 4.125305] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1200000000 (-34)
[ 4.134045] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 1199999 KHz
[ 4.142582] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 1200000000 (-34)
[ 4.181602] ata1: SATA link down (SStatus 0 SControl 330)
[ 4.182739] mmc0: SDHCI controller on ff160000.mmc [ff160000.mmc] using ADMA 64-bit
[ 4.187017] ata2: SATA link down (SStatus 0 SControl 330)
[ 4.207561] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 4.214607] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01 00:00:25 UTC (25)
[ 4.222785] of_cfs_init
[ 4.225240] of_cfs_init: OK
[ 4.228157] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.373147] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.379677] clk: Not disabling unused clocks
[ 4.383945] ALSA device list:
[ 4.386900] No soundcards found.
[ 4.390597] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.399251] cfg80211: failed to load regulatory.db
[ 4.399423] Freeing unused kernel memory: 832K
[ 4.423438] Run /init as init process
INIT: version 2.88 booting
Starting udev
[ 4.544602] udevd[1790]: starting version 3.2.5
[ 4.549429] random: udevd: uninitialized urandom read (16 bytes read)
[ 4.555928] random: udevd: uninitialized urandom read (16 bytes read)
[ 4.562438] random: udevd: uninitialized urandom read (16 bytes read)
[ 4.572940] udevd[1791]: starting eudev-3.2.5
Tue Dec 17 23:15:09 UTC 2019
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
INIT: Entering runlevel: 5
Configuring network interfaces... [ 5.310543] pps pps0: new PPS source ptp0
[ 5.314577] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[ 5.321299] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc: started, v1.29.2
udhcpc: sending discover
[ 8.379768] macb ff0e0000.ethernet eth0: link up (1000/Full)
[ 8.385442] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
udhcpc: no lease, forking to background
done.
Starting haveged: haveged: listening socket at 3
haveged: haveged starting up
Starting Dropbear SSH server: [ 14.544215] urandom_read: 5 callbacks suppressed
[ 14.544219] random: dropbearkey: uninitialized urandom read (32 bytes read)
[ 14.558481] random: dropbearkey: uninitialized urandom read (32 bytes read)
Generating 2048 bit rsa key, this may take a while...
haveged: haveged: ver: 1.9.4; arch: generic; vend: ; build: (gcc 8.2.0 CTV); collect: 128K
haveged: haveged: cpu: (VC); data: 16K (D); inst: 16K (D); idx: 11/40; sz: 15528/64688
haveged: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B): last entropy estimate 8.00069
haveged: haveged: fills: 0, generated: 0
[ 15.304436] random: crng init done
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCih6bcNPCyn0veSgu7x5d5YpDOBAG3WIFUMBzLMj+kmxRr0XrMTcGF/UKIpZ0L1PHtJhmcQz7wu5WGvlV9MjClWOZ1jD9+UkJfCwKH0tVTpf XvsKbGx1yT6icLjiSnVCFN04XQNrMHKJHJsVCe4riC/zwie2mV86Fst6GOQN5fw73eLBqkm176Exys8M3NmX9wP4MBEfJvSE5c5NR6UZXxr09bF9UMoUxscO3qbCKKW3EDseIs72fuQBzgAsR8 lgdYWlUFjNgnfc929EKUwiJTaRCR2aGOS1ZCLsfJXZ8pmRhICxGpWf79Zwar3ljZEcHILzjZjIkDWGwPzCwbQw0V root@zynq_poject
Fingerprint: sha1!! fb:60:c9:70:d9:b6:04:c8:cb:02:50:57:79:96:63:ea:43:84:23:b2
dropbear.
Starting internet superserver: inetd.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2019.2 zynq_poject /dev/ttyPS0
zynq_poject login:
