PetaLinux on Zybo Z7-10
Hello all
I tried to test the Ethernet on Digilent's Zybo Z7-10 with the Peripheral Test from XILINX.
All tests work properly, except Ethernet test.
It gives error because of XILINX software supports Marvell and TI PHY and do not supports
RTL8211E from Realtek.
Probably Ethernet will work obly under PetaLinux.
Please answer on the following questions:
- where could be found the diver for Ethernet on Zybo Z7-10 under PetaLinux ?
- where could be found ready to use Peta Linux on the SD flash for Zybo Z7-10 ?
Thank you,
Best regards,
Victor.
pulsarvictor2003@gmail.com
Re: PetaLinux on Zybo Z7-10
Hi Victor
I would suggest to reach out to Digilent forums on any of the Zybo specific files or queries: https://forum.digilentinc.com/
Best Regards
Shabbir
