gwhite
PetaLinux v2015.2.1 “petalinux-create --type project” is ignoring the --output parameter
In PetaLinux v2015.2.1, “petalinux-create --type project” is ignoring the --output parameter and using the original project name (whether the designated output directory exists or not).
gwhite
I forgot to mention that I'm also using the "--source <project>.bsp" switch to create the project from a BSP. The --output parameter specified the name of the output project directory in PetaLinux 2014.4.
achutha
@gwhite
Are you refering to --out option [this is used to place the bsp project created in the diretory you have specified] for petalinux-create ?
The --out option doesn't change the project name , it may just place the bsp project in the location you specify.
Please let me know if my understanding of your query is incorrect.
-Achutha
gwhite
Hi, @achutha ,
Yes, I'm refering to petalinux-create's --out option. Unfortunately, it no longer creates the bsp project created in the directory I specify, which can be a nasty surprise. If the --out option specifies a nonexistant subdirectory, petalinux-create replies as follows:
realpath: No such file or directory
ERROR: out directory test doesn't exist!
If I create an empty target directory and then execute the command, the target directory is left empty and the project is placed in a sibling subdirectory with the original name. Not handy if I'm trying to duplicate an existing project.
