PetaLinux won't boot from SD card on MicroZed
Vivado 2015.4
PetaLinux 2015.4
Windows 7 running VM (VirtualBox) with Ubuntu 14.04
I have the latest MicroZed board and I can build Linux with PetaLinux with no errors. Have all of the hardware requirements, ARM Core, Memory, UART, TTC, etc. After I build the BOOT.bin and image.ug files I put them on a FAT32 formatted SD card and configure my MicroZed jumpers to accept an SD boot profile. I try to connect over USB to the virtual com port and nothing happens.
I have verified with the Linux image for MicroZed that the USB/UART works fine. Just not my image. Anybody have the same issue or might know how to help? Here is how I built my image.
$ petalinux-create --type project --template zynq --name <Project_Name>
$ petalinux-config --get-hw-description –p <Project_Dir>
$ petalinux-build –x distclean
$ petalinux-config –c rootfs (run this to include my app, just does a printf("hellow world"))
$ petalinux-build
$ petalinux-package --boot --fsbl images/linux/zynq_fsbl.elf --fpga images/linux/System_wrapper.bit --uboot --force
Thanks!
Re: PetaLinux won't boot from SD card on MicroZed
Can you please follow steps from http://www.xilinx.com/support/answers/59476.html to narrow down the issue?
@smarell
I followed the guide, added some printf() debugs on my own and was eventually able to get the build to run with the SD card. Once I put the CD pin on MIO0 (and grounded MIO0) everything started working fine.
Thanks for the help!
